Very strange memory problem 8gb installed 3.74gb usable
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Is this a laptop, SODIMM memory?
    Odd it passes memtest. The BIOS reads the SPD (Serial Presence Detect) chip on the DIMMs to show it's installed.
    I think it's solved, maybe, the slot isn't working at all. Toasted as carwiz said.
    Also odd you show so much RAM as hardware reserved though.
  2. Posts : 67
       #12
    Can anyone here do BSOD dump file diagnostics? I have a post in BSOD hlp forum but nobody is answering, here is a link to that thread...if i can prove it's a memory issue causing BSOD during games, it's more evidence i have
    Blue screen in game
  3. Posts : 67
    DDr3 1333mhz
  4. Posts : 4,161
    Windows 7 Pro-x64
       #14
    I doubt that memtest even looks at hardware reserved memory. That's set and used by the BIOS. I don't think Windows will access it so neither will memtest. If the BIOS can't allocate the memory, it marks it as reserved. There used to be an option to do a full memory test on boot but it takes a while so the default was changed to a "presents test". I don't even remember seeing the option in the last 10 years or so.
  5. Posts : 67
       #15
    What about a startup test.?
    Edit: Tried, did not catch anything...
    Also the graphics are non-integrated and use its own 1gb of memory so it's not reserve for graphics
  6. Posts : 4,161
    Windows 7 Pro-x64
       #16
    From previous post:
  7. Posts : 24,479
       #17
    So it is a laptop, I was going by your specs which say desktop. It explains the pic, it is SODIMM memory, that's a physical size reference rather than type, as DDR3 is.
  8. Posts : 67
       #18
    Oops, yes i just added those specs today..fixed it
  9. Posts : 4,161
    Windows 7 Pro-x64
       #19
    I wonder about the label on the board. "Replace With HP Spare" It looks to me like it's a known defective motherboard.
  10. Posts : 67
       #20
    they all say that, my old one has that sticker on it too.
