Help Required - Building a PC
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    2x4GB RAM is plenty HyperX Black 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX16C9B1BK2/8X - Newegg.com
    You will need 2 or 4 stick of RAM, to have 12GB you would have only 3 sticks.
    4x8GB RAM sets are very expensive.
    http://www.newegg.com/Product/Produc...=-1&isNodeId=1
    Here are several Z77 board to choose from. Newegg.com - Computer Hardware, Motherboards, Intel Motherboards, Intel 7 Series
  2. Posts : 12,012
       #12
    If you are not overclocking you should not get an Intel processor with a K at the end. Models without the K are for non-overclockers. Look at other Intels a bit cheaper than the 3570k.
    If you are not overclocking you also do NOT need a motherboard with a Z87 or Z77 chipset.
    So you can save money on CPU and motherboard if not overclocking.
    You should choose the processor before worrying about a motherboard. Some Intel CPUs need a socket 1150 motherboard and others need a socket 1155. Decide on the processor first.
    I'd get either 8 or 16 RAM, not 12.
  3. Posts : 55
    Windows 7 Professional x64 Windows 8 Professional x64
    OK I have finalized everything except mobo. I think its best.
    Intel 4570 i5 - 14000
    Nvidia gtx 760 - 20000
    Ram - corsair vengeance 2x8 GB - 12000
    Psu- corsair vs550 - 3200
    HDD - Seagate barracuda 2 to - 6000
    Any case for 4000
    Please help me decide mobo for max 6000 inr.
    And finalize my PC.
  4. Posts : 12,012
       #14
    There's only 2 socket 1150 boards in your price range.
    I guess I'd go with the MSI B85M-G43 if you can't go above 6000.
    You need to check the features on that board to make sure it has what you need. It's got a B85 chipset and I don't know much about it.
    It's a micro ATX board, so should take a smallish case.
    I'd let others comment before I ordered it.
    You also need to find out if that PSU has the necessary connectors for your graphics card and motherboard.
    I'd probably go with 8 GB of RAM so I could spend the saved money elsewhere, but it's your PC, not mine.
  5. Posts : 55
       #15
    The mobo you suggested is fine and I want more than 8 GB ram so going for 16 GB. I didn't understand cable of PSU. So can you check instead of me
    That would be the final step
    Please check all sort of compatibility. I would be really greatful. Thanks for giving me time
  6. Posts : 24,479
       #16
    Abhishek1108 said:
    I think due to budget I should forget overclocking.
    Suggest a mobo for 100 USD for Intel i5 3570k.
    And one more thing
    8+4 GB ram or 4x3 GB ram?
    Suggest model also for ram at most 135 USD total for ram.
    Thanks and please reply fast.
    Are you going to buy this CPU or a i5-4570?
  7. Posts : 55
       #17
    I am going for 4570
  8. Posts : 2,409
    Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
       #18
    B85 is more business optimized. H81 or H87 would be better for his needs.
  9. Posts : 55
       #19
    H81 H81 are out of my budget. One in my budget is entry level.
    It is weak and doesn't satisfy my needs. So B85 is my choice. I think so. Thnx. But opinions are still open.
  10. Posts : 55
       #20
    Hey guys?? Where are you all??
