Help Required - Building a PC
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #21
    Abhishek1108 said:
    Hey guys?? Where are you all??
    Well, we work, go to school, sleep, go to the movies, have lives.
    Abhishek1108 said:
    I don't need an ssd. I will do with HDD. For gaming I require 16 GB but I think 12 GB will also be fine.
    I intend to overclock in the near future. Exclude cost of os. I didn't understand your rpm thing
    IF you want to overclock you will have to get a Z87 board and a K sku CPU, i5-4570K.
  2. Posts : 55
    Windows 7 Professional x64 Windows 8 Professional x64
       #22
    Abhishek1108 said:
    I think due to budget I should forget overclocking.
    I have left the idea of overclocking due to budget.
  3. Posts : 24,479
       #23
    To have overclocking ability would probably add a minimum of $200 to the project, maybe more.
  4. Posts : 55
       #24
    Its better to add an extra 150 USD and get an i7. I think so.
  5. Posts : 24,479
       #25
    No, there's not that much difference between an i5 and an i7, I have both and don't really notice a difference.
  6. Posts : 55
       #26
    So whatever I have thought and finalized is OK.
  7. Posts : 55
       #27
    What's the difference between different memory config. ( single, dual, quad channel) in one stick of ram?
  8. Posts : 2,409
    Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
       #28
    Single utilizes the ram each in different channels. Dual uses unique a channel for every two ram slots. Quad uses a unique channel for every four ram slots. This is the reason why you have to put in ram in specific slots if not all of them are occupied. The slots are arranged differently for different MB manufacturers. But most times, if it is dual channel, slot 1 and slot 3 are supposed to be occupied if using only two sticks. Most consumers need only dual channel. Quad channel is meant for servers and workstations where ram is heavily used.
  9. Posts : 24,479
       #29
    Basically, dual channel is twice as fast as single and Quad 4 times as fast. Multi channel will access more RAM in the same CPU cycle.
  10. Posts : 12,012
       #30
    Your PC will run fine in single or dual channel. Dual channel means utilizing the correct 2 or 4 slots. If you use just one slot, it will be single channel. Dual channel is faster, but you'd be hard pressed to notice the difference in most operations.
    The RAM stick itself is not "single" or "dual" or "quad". It's the platform (motherboard) that determines that. With one stick, you are going to be in single channel, regardless. The difference between one 8 gb stick in single channel and two 4 gb sticks in dual channel is small.
