Mouse double clicks when I click once and click when I hold it.
  1. Posts : 93
    windows 7 ultimate x64
    What I mean is that let's say I am trying to hold and drag a desktop file it will sometimes just click, making me drop the file on the spot. It will also double click when I try to make a single click. I tried to lower the settings for double click timing on the settings menu.
    EDIT: Tried out another mouse, it doesn't click out of nowhere but is there a way to fix my old mouse? I can switch the buttons so right click acts as left click so it seems that specific button got practically destroyed
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Do you mean the other mouse works fine? As far as I know there's no way to fix a mouse other than making sure the trackball or optical lens is clean, whichever your has.
    A repair would cost more than a new mouse I suspect. You can get an ordinary one for about $5 or so.
  3. Posts : 93
    The other mouse worked just fine but now the old(broken?) mouse works again. How is it even possible for a mouse to periodically click on it's own and fix itself given time?
  4. Posts : 24,479
    Bad cable, LED, or electronic snafu. It'll likely quit working again.
  5. Posts : 93
    Good night sweet mouse.
    Thanks for the help
  6. Posts : 1
    Windows 10 Home 64x
    I have a temporary fix for anyone who doesn't want to fix their mouse or buy a new one!
    Go to: www.clickfix.cf
    It takes less than 5 minutes to set up, guaranteed (by me anyway )
