Odd issue need help with
  1. Posts : 5
    windows ultimate 32bit
    I installed a new DVD drive in my alienware, since then I was in the BSOD loop that is caused by RzFilter.sys. once the BSOD loop was resolved I am now able to get to the windows login screen but not able to type, I have tried two different keyboards no difference, yet if I try going to the boot menu I am able to use my keyboard to choose between the options. can anyone offer assistance?
  2. Posts : 26,869
    Windows 11 Pro
    RzFilter.sys is usually associated with Razor Products. Do you have a Razor mouse or Keyboard? I suspect you do or did. Perhaps if you have one, uninstall the software and reinstall the latest software from Razor. If you used to have one but no longer do, I suggest uninstalling the software. I doubt it has much to do with the new DVD drive.
  3. Posts : 5
    I have never had Razor as much as I want to, the only difference was the new DVD I know it doesnt make sense lol, but since I once I put the new DVD drive in I had the BSOD loop, deleted the RzFilter and it fixed it, I can now get to the screen where windows prompts for my password but I cant type so I cant type so I cant type in my password
  4. Posts : 38
    Have you tried to boot Windows in safe mode and find out if you can pass the login screen using your keyboard?
  5. Posts : 25,847
    How about unplugging the unnamed DVD Player.
    Has this computer ever worked properly with the DVD Player plugged in?
  6. Posts : 5
    @frozwire, I have tried safe mode but whenever (in any way shape or form) I get to the windows login I cant type, I dont know abut after logging in since I cant log in lol
    @layback my box has one DVD that it has worked with for years, since I installed the additional one it stopped working, I removed it to attempt to fix it and had the loop
  7. Posts : 26,869
    Windows 11 Pro
    Does the DVD work? Put in a bootable disk such as the Windows installation disk and see if the keyboard works. If it does, try to restore your computer to a time before the keyboard stopped working.
  8. Posts : 5
    if I go to the boot menu I am able to use my keyboard to choose the options so it does work, but I am unable to type once it gets to the windows screen, and I dont have a system restore point
  9. Posts : 5
    I went to an option that says repair your computer and it asks for something from bitlocker, and it seems I can type numbers but not letters
  10. Posts : 26,869
    Windows 11 Pro
    I suggest you try a different keyboard. Maybe that will help. Otherwise you are most likely looking at a repair install or a clean install. Try this, if you can. Boot from the installation disk with another external drive or a larg USB drive attached. When you get to where is says 'where do you want to install windows, click on advanced options, and then click on load drivers. It will ask where the drivers you want to load are and give you a search box that shows all drives connected.. Go to your OS drive, navigate to C:/windows/minidump and copy all the files inside and paste them to your external drive. On another computer insert the external drive/USB drive R highlight all the dump files you pasted, and right click and select send to and select compressed zip folder. Upload them with your next post using the paperclip icon in the reply window. See if you can do that.
