Num Lock, Caps Lock and Scroll Lock all lights up (not blinking)
  1. Posts : 76
    MS Windows 7 Home Premium 64-bit
    For some time now, i have been experiencing that my Num Lock, Caps Lock and Scroll Lock all lights up (not blinking) all at the same time, I tried to google it but i can not find any solutions or explanations for it.
    Does anyone know if it is bad? and what is causing this?
    I am having a wired keyboard with nothing fancy just a standard issue Logitech keyboard.
  2. Posts : 1,519
    Can you toggle those functions off, one at a time? Sometimes restarting the computer will use the last state it was in, I'd fully shut down and pull the power cord from the computer and the keyboard cable then put them back and try again.
  3. Posts : 76
    yea I can, right after posting this my keyboard "lit up" and when i hit one of the "lock" keys they all turn off again, after a while (3 mins or so) my keyboard stopped responding, so i turned off the pc, pulled the cable to my keyboard (its PS2 btw). then i took a brand new tooth brush and started brushing the socket on the cable, now its working again.
    but I reckon this happening before, so i was thinking if those lights meant some kind of hardware faliure. ?
