#21
and is nothing i can do ? without going and change bios version ?
Windows is not original
And yes,all the function work
No real Option to change BIOS
- If the notebook you purchased has Win7 Bios installed, please DON'T attempt to update using Windows 8 bios (or vice versa). Failure to abide may result in bricking your system.
- Although there's a bios detection program written to protect user from cross flashing the bios (Win7 to Win8 bios or vice versa), still DON'T experiment. Failure to abide may result in breaking your system.
I know,i wanst thinking.well,i will have to leave it like this.at least,until i will decide to go back to win8
Thank u for ur time
I did,the killer one.i will try it tomorrow all of them.:)
