Bluetooth problem
Page 3 of 3 FirstFirst 123
  1. Posts : 16
    windows 7 x64
       #21
    and is nothing i can do ? without going and change bios version ?
  2. Posts : 18,415
    windows 7 home 64bit
       #22
    Where did you get the Windows 7 from ? Also does your Function Keys work ?
  3. Posts : 16
    windows 7 x64
       #23
    Windows is not original
  4. Posts : 16
    windows 7 x64
       #24
    And yes,all the function work
  5. Posts : 18,415
       #25
    No real Option to change BIOS
    - If the notebook you purchased has Win7 Bios installed, please DON'T attempt to update using Windows 8 bios (or vice versa). Failure to abide may result in bricking your system.
    - Although there's a bios detection program written to protect user from cross flashing the bios (Win7 to Win8 bios or vice versa), still DON'T experiment. Failure to abide may result in breaking your system.
  6. Posts : 16
    windows 7 x64
       #26
    I know,i wanst thinking.well,i will have to leave it like this.at least,until i will decide to go back to win8
    Thank u for ur time
  7. Posts : 18,415
       #27
    You have tried the Driver below ...
    Driver Downloads | Qualcomm Atheros, Inc.
  8. Posts : 16
    windows 7 x64
       #28
    I did,the killer one.i will try it tomorrow all of them.:)
  9. Posts : 18,415
       #29
    Okay Please keep us Posted with your progress :)
