OnBoard Ethernet and PCI sound Card don't work together
  1. Posts : 7
    Windows 7 Ultimate 32bit
    I have recently invested in a new PCI sound card to enable 5.1 surround sound. One problem, after restarting my PC after installing the drivers my onboard Ethernet adapter no longer works. In device manager it has an orange warning triangle on and on the task bar a red 'x'. When I look at the properties it says (Error Code 10)
    Please help! I don't want to have to send it back!
  2. Posts : 18,415
    windows 7 home 64bit
    Hi Welcome to Seven Forums ... Check in the BIOS to see if the Network Card is enabled ...
  3. Posts : 7
    Its enabled. I had a look and couldn't find anything else...
    Attached Thumbnails Attached Thumbnails OnBoard Ethernet and PCI sound Card don't work together-img_20150106_170613910.jpg
  4. Posts : 18,415
    If you remove the Sound Card does the Lan Connection work ? ...
  5. Posts : 7
    Yeah. It does. I've disabled the sound card and restarted to see if that works.
  6. Posts : 7
    No lights on the land connection.
  7. Posts : 7
    Okay, if I boot with the sound card disables the LAN works. But boot enebled it doesn't!
  8. Posts : 18,415
    See if you can update the Chipset Driver ... Go to the Motherboards Website ....
