Enable test mode to solve USB problems?
Page 5 of 32 FirstFirst ... 3456715 ... LastLast
  1. Posts : 6,458
       #41
    I can't find a reference to F.0b on HP for anything other than a ProLiant server and that's only in the service pack name, not a BIOS.
    So I'm stumped where that version came from.
    The only logical thing to do is to defer to the BIOS version on the HP support page for your machine.
    This makes a bit of sense in that the USB 3.0 ports require additional drivers to work properly, it was the USB 2.0 port that troubled me.
    I'll wait until I see the other information I requested before giving the green light on BIOS F.0A
    Go ahead and download it
    Do NOT install it until I see what Windows Update gave you in the option offers and what Device Manager reports as the device errors, ok?
    Bill
  2. Posts : 131
    Windows 7 Home Premium 64 bit
       #42
    I had to feed my husband. I am now back on the case. I just got a message that the chipset I am trying to install is an older version than the one on my computer. The one on my computer is version 9.3.0.1021. Should I install the older one or abort this mission?
  3. Posts : 131
       #43
    screen shots
    Here are those screen shots of device manager.
    Attached Thumbnails Attached Thumbnails Enable test mode to solve USB problems?-screenshot-usb3.0.png   Enable test mode to solve USB problems?-screenshot-controller-1e2d.png   Enable test mode to solve USB problems?-controller-1e26-screenshot.png
  4. Posts : 6,458
       #44
    I'm guessing that you aborted the install - best thing to do.
    That was the cosmetic chipset driver - right?
    The one from HP is version 9.3.0.1019, so I suppose Windows Update is doing it's job.
    Regarding the USB controllers screenshots in Device Mgr (don't worry about the Vista reference)
    scratching his head
    Code 52: Windows cannot verify the digital signature for the drivers required for this device
    Published: May 27, 2010
    Updated: May 27, 2010
    Applies To: Windows Server 2008, Windows Vista
    Device Manager displays the following message in the Device Properties dialog box, on the General tab, in the Device Status text box:
    Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
    Diagnosis
    The driver may be unsigned or corrupted.
    Resolution
    Try one of the following:
    • If the device is a CD or DVD drive, use the Automated Troubleshooting Service, at the Microsoft Support Web site.
    • Go to the device manufacturer’s Web site and download and install the latest appropriate driver for the device.
    • Search for possible solutions for your particular device on the Microsoft Support Web site. For example, for issues related with an iPod, you might search for “code 52” iPod.
    None of that is really very useful.
    Bullet 1: doesn't apply, but the troubleshooters in Win7 might help. Let me chew on this for a bit.
    Bullet 2: You already did that.
    Bullet 3: Will take additional research
    I think the best approach is to uninstall all three of those drivers
    So you don't battle Windows Update, change the option to Check but let me decide when to download and install.
    If you don't Windows, then the updates might be downloading and installing in the background while you're trying to manage the drivers in the foreground. This is only temporary, you can change it back to automatic after you are done this exercise.
    After changing Windows Update (WU), launch Device manager and uninstall the three problem devices
    If there is a prompt or checkbox regarding uninstalling the software for the driver, answer or select yes
    Restart the machine and post the Device manager screenshot(s) General tab for the three devices again.
    I suspect all three devices will be unknown, but they might still have software on the system.
    Check the General tab - if you see:
    The drivers for this device are not installed. (Code 28)
    in the status box, then you're good and you can try installing the USB chipset driver again.
    It should still be on your system, perhaps your Downloads folder, the file name is sp56164.exe
    But...but, HP unpacks their software into C:\SwSetup\filename so look there first for a folder named sp56164. Inside that folder should be a setup.exe - that is what really installs the software.
    If I explained all that well enough and you understand - use that setup to install the USB Chipset drivers.
    Check what Device Manager thinks about the freshly installed driver
    code 52 will require a different tact - turning off Driver Signature Enforcement.
    So there are at least tow more things to try if the above fails. There's still BIOS F.0A
    I'm not sure which should be done first. If you have questions - please feel free to ask. I'll be on and off for the next few hours.
    Sort version:
    Change Windows update option - not automatic
    Uninstall the problem devices in Device manager, remove software for the drivers
    resetart
    check device manager and devices (code 28 is good)
    reinstall USB chipset from C:\SwSetup\sp56164
    I know this is frustrating, if the machine was in front of me (or visa-versa), it wouldn't take as long. That unfortunately is the nature of trouble shooting in a forum - it's not real time.
    Thanks for being patient, the third possibility was raised in the code 52 message - there might be malicious code on the box. I want to stress MIGHT. Some people get upset when they hear that - we know a lot more than when we started and after the next steps we'll know more. Checking your system for malware will be a step in the process, it's only a matter of which step 4 or 9 (numbers picked randomly with no assigned importance).
    Onward and Upward. I'll see how far you get with those instructions and based on the results, provide the remaining steps.
    Bill
  5. Posts : 131
       #45
    After uninstalling and rebooting, the device manager screenshots look exactly the same as last time. All are code 52.
    I'm posting a screen shot of Microsoft Update because I am wondering if I should uncheck the bofx that says: "Give me updates for Microsoft products etc..." Could that be downloading something in the background?
    Also posting screen shot of box that came up after I uninstalled devices and rebooted.
    As I mentioned, the general tab under each device looks exactly the same as the ones I sent previously.
    Attached Thumbnails Attached Thumbnails Enable test mode to solve USB problems?-microsoft-update-screen-shot.png   Enable test mode to solve USB problems?-device-driver-software-not-installed-screenshot.png
  6. Posts : 725
    Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
       #46
    If I might also try to help. First, I'd like to collect some additional diagnostic data
    List any Problem devices
    • Make sure devices are connected and powered on
    • Click the Start Orb, type msinfo32 in the search box. Hit Enter
    • Click the + sign next to Components to expand it
    • Click Problem Devices. Anything appear?
    • If yes, click on it, Ctrl-A to select all, Ctrl-C to copy it, Ctrl-V to paste into next post
    • On the other hand, if no devices are listed, tell me so
    Generate and attach a DirectX report
    • Click the Start Orb, enter dxdiag in the search box
    • When DxDiag opens, look along the buttons at the bottom of the DxDiag window
      ===> If you’re running 64 bit Windows, you’ll see a 64-bit DxDiag button. Click it to run the 64-bit version of dxdiag
    • Notice progress in lower left window corner
    • When done, click Save Information button and save as a text file to your Desktop
    • Upload the file to your next post
    @Slartybart
    This Chipset update seems as though it only changes the name shown in Device manager.
    fyi the name change... Manufacturers burn Plug and Play ID info into device firmware. This includes a device description string.
    > When Windows can't find a device driver (this is the case when device is listed under "Other" device), Device Manager displays the PnP device description from the mfr for device name
    > Once Windows finds a driver, Device Mgr shows the name found in the driver
    That's why the Chipset install changed the device name. The chipset install provided a driver (tho unfortunately the device still doesn't work )
    /* EDIT */
    Ugh. It's not a BIOS issue. I just looked up Code 52: Windows cannot verify the digital signature for the drivers required for this device. Which would also indicate is certainly a software issue.
  7. Posts : 131
       #47
    ComputerGeek, here is what I got in problem devices:
    Intel(R) USB 3.0 eXtensible Host Controller PCI\VEN_8086&DEV_1E31&SUBSYS_1818103C&REV_04\3&11583659&0&A0 This device is working properly.
    Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D PCI\VEN_8086&DEV_1E2D&SUBSYS_1818103C&REV_04\3&11583659&0&D0 This device is working properly.
    Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26 PCI\VEN_8086&DEV_1E26&SUBSYS_1818103C&REV_04\3&11583659&0&E8 This device is working properly.
  8. Posts : 131
       #48
    Here is the directx text file.
    Enable test mode to solve USB problems? Attached Files
  9. Posts : 6,458
       #49
    The Give me updates for Microsoft products really only affects things such as MS Office, and ancillary offers such as Silverlight, Bing.....
    It doesn't have any bearing on what you're trying to accomplish.
    The second dialog is interesting - thanks for posting that.
    Check one more automatic update setting and temporarily disable it if enabled
    Launch Control Panel -> Devices and Printers
    Right click on the Computer icon (it should be labeled with the name of your computer)
    Select Device installation settings from the context menu
    Change the settings to match the image below and press the [Save] button
    If the settings were already set that way, please let me know.
    I guess I should ask some questions I should have already asked
    1) Is the user id you log in an administrator id or a standard id?
    2) Your specs say Anti-Virus: Microsoft. Is that Microsoft Defender or Microsoft Security Essentials (MSE)?
    -> If MSE. when was the last scan performed and were there any threats discovered?
    Bill
  10. Posts : 131
       #50
    I'm going to bed now and hope the good fairy fixes my usb ports while I sleep.
