#151
Ah, I see - the restore point to you did before got your touchpad back. There was nothing stupid about what you did. You picked the earliest one available to you.
Drivers that don't come from the vendor (PC maker or part maker) are always suspect. It is a practice that I tell folks NEVER to do.
Members have fixed many, many, many issues on this forum simply by telling the other member to reinstall a driver from the maker. It happens a lot. The information from the site you linked appears to be identical to what HP reports.
Driver Name: HP Notebook System BIOS Update (Intel Processors)
Driver Version: F.0B
Release Date: 2011-03-25
Anti-virus (AV) ... yes, it says that ... but I don't think it's all that important - I've flashed BIOS 100s of time and I have yet to disable AV. To be honest, I forget about it when I'm doing it. It's a moot point now. :)
Good for you! BIOS can be scary because it does have the potential to brick a system if done wrong. People always put the scare into you as well - like the tech guy. BIOS should be carefully researched and only flashed when the update fixes an issue on your machine that the machine is exhibiting. The only other case is to correct a BIOS version. Flashing BIOS just to get the highest version is wrong. BIOS is not like any other software on your machine - it is not something you need to update just to update. There should be a very good reason.
I'm curious about the dates.
F.0B shows 2011-03-25
F.0A shows 2012-05-11
Those dates come from HP (Guru also has the 2011-03-25 date)
I checked your previous Speccy log and yep, it reports the date you posted. Dates are always strange - is it the date the information was posted, the internal date of the program, the modified, created, or accessed date. If there's a significant difference, I dig deeper. In this case the F.0B BIOS was wrong per HP, so that date doesn't matter. it could be yesterday and it would still be the wrong BIOS for your machine.
BIOS is correct on your machine.
The flash should have set BIOS to defaults, but it might also have read what was there and restored those values to the new microcode.
Restart the machine and go into BIOS - load default and save
That guarantees your machine has the default values - no guessing.
Hold off on starting services or startup objects.
Uninstall the USB devices - yes to remove software if that is an option
Restart your machine
Manually run Windows Update (WU) and look in the optional offerings. Select them all
press the install button
Restart the machine when WU finishes.
I'll pick up tomorrow.
Bill
