Enable test mode to solve USB problems?
Page 21 of 32 FirstFirst ... 11192021222331 ... LastLast
  1. Posts : 6,458
       #201
    I had to check the Mbam tutorial mainly because of your questions.
    Step 8 instructs you to clean
    Step 9 instructs you to repair
    Step 10 instructs you to attach
    It might have been a communication breakdown - I said you could skip the VirusTotal step. That might have been interpreted as you could stop at that step.
    Read, not skim, Bill
    Oh wait - there's that stop sign - - you're really good Crabby, you know that.
    I had to check my own work to make sure I gave the correct instructions in the tutorial.
    It looks as though I need to change the Clean step or add instructions for cases like this one.
    I have to revisit the tutorial anyway, Mbam has changed a bit [action dropdown boxes instead of checkboxes] - thanks for bringing these things to my attention.
    Step 9 SFC scan, did you run that after the scan? Please do after the scan that is running
    Step 10 attach - this is the one that really made me think the tutorial needed attention. I thought I had the location in that step.
    I did - phew!
    Mbam logs: C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\Logs
    The logs you attached were in xml, and I understand the difficulty you had with empty text files.
    Try this with after the current scan
    - quarantine all
    go to History, application logs
    double click on the most recent log (should be a later time than 14-59-30 | 2:59:30)
    click the export button and select .txt
    save it to your Downloads folder and name it MbamRootScan.txt
    I hope I covered everything,
    Bill
    Last edited by Slartybart; 17 Jan 2015 at 11:29. Reason: clarify that Crabby is the one who is ok
  2. Posts : 131
    Windows 7 Home Premium 64 bit
       #202
    I ran the scan again after telling the software to do the recommended actions, which I thought were quarantines, but maybe it wiped them out completely because the new scan didn't find any threats. Here is a screenshot.
    Gator, I will try to keep my palms off the touchpad. I don't want to disable it because then I will have no mouse.
    Attached Thumbnails Attached Thumbnails Enable test mode to solve USB problems?-malwarebytes-screen-jan-16-no-threats.png
  3. Posts : 131
       #203
    I just looked at Malwarebytes again under the history tab and it looks like the former potential threats were quarantined.
    I will check back in the morning since everyone will now be at happy hour.
  4. Posts : 6,458
       #204
    Thanks Crabby,
    The last Mbam screenshot looks clean. I'll finish checking the original log and will post anything that I think needs to be done.
    One step forward ... I'll post the information CompGeek wants and then I'm out to Happy Hours. I'll probably fade fast though.
    Here ya go Jerry,
    I used the Date field instead of Date Created & Date Modified. It saved some room
    I also added a column for Version and sorted by Folder path
    Reported dates are often confusing, for instance when I had the date fields in your example, the creation was later than the modification.
    All Attributes are Archive (A) - no other attribute is set on my Dell for theses files.
    Let me know if you need anything else off of this machine and I'll drag it out of the closet again
    Bill
  5. Posts : 6,458
       #205
    @Crabby, after skimming (yeah, I know, I'll read it later) the original Mbam log, there is only one thing I really want to check.
    Please post the TDSSkiller log - I know you said it was clean. The one thing Mbam reported that I want to check is a fairly generic name. The one bad threat would have been detected and remedied by TDSSkiller, the other versions are just PUPs and Mbam remedied that one. Where there's one there's usually more.
    At this point the machine is looking a lot better re: malware.
    Here's where you should find the log I want to see.
    The log file is placed on the System Drive (normally C:\) with the file naming convention:
    TDSSKiller.Maj#. Min#. Bld#.Rev#_MM.DD.YYYY_HH.MM.SS_log.txt
    Example:
    C:\TDSSKiller.3.0.0.17_03.15.2014_12.03.49_log.txt
    The numbers will be different but the prefix (TDSSKiller), suffix (_log) and extension (txt) should be the same.
    Thanks,
    Bill
  6. Posts : 131
       #206
    Here are the TDSSKiller logs. I ran it twice, before and after disabling system restore/hybernate.
  7. Posts : 725
    Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
       #207
    Here ya go Jerry,
    Thanks for the snapshot Slartybart! These snapshots help me see the DriverStore folders on your computer and Crabby's computer. (@Crabby - Could you also provide a snapshot per my post #190)
    Windows DriverStore
    Starting with Vista, Windows introduced the "DriverStore". When a driver is submitted for installation, it must first be "staged". "Staging" means the driver files are submitted to Windows for inspection. Windows checks that the files in the driver package meets digital signature and all its other driver spec requirements. IF it does, then AND ONLY then, the driver package is loaded into the DriverStore. The "package" is the set of files that make up the driver. So, note each driverstore folder contains a driver "package". Windows is supposed to protect files in the DriverStore from being tampered.
    Your computer may have more then one "instance" of a hardware device. For example, Crabby has TWO USB 2.0 controllers. When the first hardware instance is installed, it only installs if its driver files are found in the DriverStore. Installation copies the files needed from the store and they're placed in their proper run-time location (e.g. they may get copied into C:\Windows\system32\drivers or other locations)
    Slarty, your snapshot shows you have two different versions of the USB 2.0 driver in your store. (Also note the DriverStore naming convention for folders also tells you the architecture that driver is for. amd64 for your case.) If you look at the run-time file version of the file in C:\Windows\system32\drivers you see the run-time version equals the latest of the versions found in the store - which is good and what I would expect.
    Next steps:
    > Slarty could you run the script i posted in #114 and attach the file output
    > Crabby could you also post the screen shot. I'd like to see how your DriverStore is organized
    Then i can go on and explain more
  8. Posts : 131
       #208
    Here is the search my files screenshot.
    Attached Thumbnails Attached Thumbnails Enable test mode to solve USB problems?-screen-shot-search-my-files-jan.-16.png
  9. Posts : 6,458
       #209
    Don't explain for my benefit, it detracts from what I thought you wanted to do - the security catalog.
    I mentioned that I thought I saw something about repairing/rebuilding it.
    Catalogs screwed (again) [FIXED] - Sysinternals Forums - Page 1
    Solution
    1. Stop Cryptographic Services (cryptsvc) by running "net stop cryptsvc".
    2. Delete or rename the C:\Windows\System32\catroot2 folder.
    3. Start cryptsvc by running "net start cryptsvc".
    4. C:\Windows\System32\catroot2 will be recreated. If it is not, restart the computer.
    5. Wait for all the catalog files from C:\Windows\System32\catroot to be imported into the catroot2 database. This may take up to an hour, so be patient.
    And this is where I thought you were heading (I found a reference, I'm not sure if it the reference I saw before, but it fits the bill, er Jerry :))
    This is a discussion, not a task to be completed.
    Give CompGeek a chance to say "Yeah, that's what I was going to do" or "No don't do that!"
    DO NOT hit enter Crabby
  10. Posts : 6,458
       #210
    Time for a recap.
    The Issue: Three USB 3.0 ports, one USB 2.0 port on the machine. None work
    Device Manager:
    USB 2.0 devices report code 52 under Universal Serial Bus category
    USB 3.0 devices report code 28 (no driver) under Unknown devices
    Installing the chipset driver for the USB 3.0 device from HP downloads moves it out of the unknown category and into the Universal Serial Bus category but reports code 52
    Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
    The hardware tested good (it worked) using an Ubuntu boot.
    ComputerGeek suggested fixing the signatures either on the individual drivers or on a global scale.
    Malware scans to date do not indicate anything serious.
    Other related tasks (not necessarily in this order):
    completed: Clean startup
    completed: Disable hibernation and System Protection to avoid resurrecting the issue
    completed: Windows Update changed to manual to avoid thrashing and control when updates are installed
    completed: Disable Device Update to avoid battle with automatic updating of a device
    completed: create Repair disc
    completed: BIOS flashed to correct version F.0A
    completed: C:\SwSetup renamed to move the HP install path out of the way
    completed: System File Checker - mapi hash mismatch, fixed by NoelDP (unrelated to the USB issue)
    Other things considered:
    Clean Install: ruled out for various reasons.
    Repair install: still considered, but have not prepared
    System Drivers are not affected by a Repair install
    Observations:
    HP Recovery partition is visible - unusual for an HP
    HP unpack folder, C:\SwSetp, had an odd tree structure (see above)
    The touchpad update from WU breaks the touchpad - this is not that uncommon, so the update is hidden
    Windows is up-to-date
    What bugs me:
    The code 52 indicates an unsigned driver or malware. Malware scans look good and the USB 3.0 driver has been freshly reinstalled (uninstall in DevMgr removing software). It's possible, but unlikely, that the HP drivers are bad (unsigned). This points more to what ComputerGeek is thinking - the store is corrupt.
    There are probably things I missed, but this provides everyone with the same information I have in one tidy package. If I got something wrong writing it from memory - let me know and I'll correct it - thanks.
    What's left (not necessarily in this order)
    • Create install media - just in case we need it Done
    • Disable Driver Signature Enforcement Done - this solved the USB 2.0 ports issue but not the USB 3.0 issue
    • Repair/ rebuild the catroot2 store
    • Determine if the individual driver signature for the affected drivers is the culprit.
    • Determine if another driver is causing the issue (ComputerGeek commented that this is a possibility and CrabbyRightNow indicated that the NVidia driver was updated (WU) around the time this started)
    • Continue malware scans
    • Apply the HP QFE
    • Repair install
    There is order in the Universe and in trouble shooting computer issues
    Bill
    Last edited by Slartybart; 20 Jan 2015 at 23:05. Reason: strike Repair install - won't replace system drivers
