USB Problem!
  1. Posts : 22
    USB Problem!
    Hi, Recently I have been trying to fix my USB. I plug it in and it say's it's connected but when I go into Computer Management, I get this problem. Been doing research and been trying to fix it but I can't find a solution.
    Thanks for the help!
    Attached Thumbnails Attached Thumbnails USB Problem!-screenshot014-cropped.jpg   USB Problem!-screenshot015-cropped.jpg   USB Problem!-screenshot011-cropped.jpg
  2. Posts : 17,796
    If it is for storage of information, I think that you have to format first.
  3. Posts : 22
    How do I format it?
  4. Posts : 17,796
    Before doing this be sure that you are formatting the correct drive. If you format c you will lose EVERYTHING
    Connect the USB drive, go to > Computer or > My Computer, right-click the drive and select > Format… from the menu.
  5. Posts : 22
    Can't see it on My Computer either.
  6. Posts : 17,796
    Take a USB that you have used before and you know is good. Do you see it in computer?
  7. Posts : 22
    Yeah, I can see it.
  8. Posts : 17,796
    If you have another computer, can you see the USB there?
  9. Posts : 22
    Yeah, I can see it.
  10. Posts : 17,796
    You can see the problem USB in the second computer?
