Need help with installing hard drive
First, I'm running Windows 7x64 Ultimate. I recently bought 2 Samsung 850 EVOs to setup in RAID0, and I bought a WB Black 4TB drive to increase my storage. After hooking everything up, I setup the RAID array, but then discovered my system used both SSDs and a portion of my WD Black drive to setup the RAID array. So, I removed the RAID and then rebuilt it using only the two SSDs.
I then proceeded to partition the WD Black drive using GPT, and when I go into Disk Management, it shows all my drives being partitioned and allocated, but I only have 3725.84GB free on the 4TB WD Black drive. When I view the properties of the disk, it shows 250GB being used but I can't find this anywhere. I've removed the partition, recreated the partition, I've removed the RAID arrays where Windows shows two separate drives, but I still can't find out what happened to the rest of my drive. Does anyone have any suggestions?
