X is always the recovery, as far as I know.
I've tried booting from boot X but the only bootable files I've found in there are drives for all components of computer and they do nothing. So before I got the BSOD, I was casually reading a user manual to some lights I had purchased in a pdf file. I was also running a full scan in malware bytes (but I had scanned my PC the day before and it was fine.) I went to go try something with the lights and left the computer on, came back about 20 minutes later and it was asleep, which is normal obviously, but when o go to wake it up, it takes longer than usual and about 15 seconds after I wake it up I get a bluescreen. I don't recall what it all said, but the beginning said "if this is your first time seeing this restart your computer". Upon restarting I got the error reboot and boot from proper media device and that's when I began troubleshooting. I'm in the middle of opening my computer right now. This is my progress so far.
Update: messed around inside the computer for a little. I don't have any extra SATA cables so I just swapped the DVDs drive SATA cable and the hard drive SATA cable, but the hard drive still doesn't show in bios. In the missilaneous tab AHCI ports 0 and 1 are not present but AHCI port 2 reads the DVD drive ( the hard drive is connected to port 0 inside the computer). Can this just be a dead hard drive? Or would it be cheaper to go get this fixed with geeksquad?
Any friends to test that drive? Or at school/job?
Sorry I was busy today, but no my friend isn't here this week and I'd have to purchase the SATA to usb cable. Although I have looked deeper into the boot X and was able to open the registry and see the mounted devices. There are 3 listed. 1st seems to be my hard drive but it isn't recongnized, the last two are my dvd drive and boot X in that order. Any information we can pull from this?
Yes I suppose too.
Yes, this is standard, how BSOD screens start. :)
Yes, it could be a dead drive, you should try to connect it externally to another system using a SATA to USB adapter. But from the description I could only assume it could also be dead ports. Connect the drive with the DVD drive's cable on its port, see what happens.
Plus, after you test these options, or you don't, a professional is always a good idea. :)
Hardly so. You will have to get into the drive itself. :/
Post back after you try the options from above!
CK_WD
