These new parts compatible?
  1. Posts : 175
    Windows 8.1 PRO
    So I am going to be upgrading my system really soon
    Already upgraded the GPU and the PSU,
    I would love some of your expert advice on my pickings
    New specs
    CPU= i7 4790K
    Motherboard= Gigabyte Z97X-Gaming 7 motherboard
    I would also like to ask is the h90 a good cooler for the i7 I have picked?
    And will this Case Zalman Z11 Plus Midi Tower Gaming Case
    work with the Corsair h90 CPU cooler?
    I picked out that case as it has 140mm support but on the specs it says = 120mm/140mm Fan Vent just making sure that it will fit
    thanks for reading my post
  2. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
    Not so sure the cpu cooler will fit anywhere but the front of the case :/
    It's a 140mm and all you have is 120mm fans on the case,
    Being the rear I guess is the most likely place for the cpu cooler but these radiators like to be intakes not exhausts but several people have used them as exhausts without issue
    I prefer as a intake which would put the rad at the front of the case
    The case does look wide enough on the front for a 140mm fan on it but I don't see on Newegg where it states there's enough room ? blue fan is 120mm and blue led,
    But the top is the most common location for a radiator,
    ZALMAN Z11 Plus Black Steel / Plastic ATX Mid Tower Computer Case - Newegg.com
    Attachment 367863
    So it would seem this cpu cooler would fit in 3 locations being it has 120mm fans
    Corsair Hydro Series? H80i GT High Performance Water/Liquid CPU Cooler. 120mm - Newegg.com
    I have no idea where the 2-80mm fans are located on the case :/
  3. Posts : 175
    Windows 8.1 PRO
    Hi thanks for the reply, was also asking on Overclockers fourms, and decided to change case and cooler, I am going to go with a H80i and another Case, just for price and fitting, thanks for the detailed reply, I am going to keep my options open in the next few weeks :)
  4. Posts : 20,583
    If you get a new case these would be better for the cpu your buying,
    A 120mmx 240mm
    Corsair Hydro Series? H100i GTX Extreme Performance Water/Liquid CPU Cooler. 240mm - Newegg.com
    I have this one mounted on the front of my case which is a Corsair 450D mid tower,
    The 120mmx240mm would fit best on the top of the 450D
    Or 140mmx280mm on the front I did have to remove most of the extra hdd trays though I didn't need them anyway
    Corsair Hydro Series H110i GT High Performance Water/Liquid CPU Cooler. 280mm - Newegg.com
