CSR Bluetooth USB dongle v2.1 help - icon not appearing on taskbar
I bought a USB dongle from Argos and actually went back to get it replaced in case it was the unit before posting here, but my issue persists.
The instillation instructions provided with the device, as well as those of multiple other sources, all say to do the following;
1. plug in the device and the computer will detect and install driver automatically ✓
2. click on bluetooth icon that appears in the bottom right on the taskbar. ✗
No icon appears on the taskbar and even though on Devices and Printers window it registers the device properly with no errors, when trying to go through the settings it does not think the device is plugged in.
in fact, at first nothing even happened when I'd right click on the bluetooth device and click "Bluetooth properties". it only started responding after I went to Services and stopped the bluetooth service and restarted it. before then, nothing would come up at all.
but still it doesn't realise it's plugged in and nothing is appearing on the taskbar. the driver SHOULD be installed okay but nothing is working.
Do I need to install anything or do anything? help would be very much appreciated. I just bought a bluetooth keyboard and would very much like to use it.
