CTRL-A disabled, CTRL Key Works, A Key Works, Other CTRL-combos work
  1. Posts : 5
    Thread title pretty much sums it up: CTRL-A disabled, CTRL Key Works, A Key Works, Other CTRL-combos work. I use CTRL-V, CTRL-C, CTRL-Z, etc all the time.
    CTRL-A has never worked for me, in any application. Instead of selecting all, CTRL-A pastes, the same as CTRL-V, only when you use CTRL-A, in addition to pasting, it also makes a system sound, kind of like a knock sound. Out of desperation to identify the sound I looked control panel sounds and listened to all of them, it's not there.
    I've never really needed CTRL-A until now because I'm wanting to use a specific application that has no other way to select all except CTRL-A, so I'm now desperate...
    Any help will be much appreciated.
  2. Posts : 21,004
    Hello Dave mate have you run either of these
    https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    https://www.sevenforums.com/tutorials/433-disk-check.html< if necessary include the /f and /r in the command line as per Option2
    if not do them in safe mode and see if that fixes the problem.
