HO Power Help
  1. Posts : 81
    Win 7 Pro 64 bit
    HO Power Help
    Long story, short version, Supposed to be in a house in April. Everything is in 4 storage lockers for 6 months. Finally got a place (supposed to close on Sept 27. I have an Officejet 8620 I don't remember if this thing uses a power supply or not. I have the cable but no power supply. I don't even remember if it uses a power supply. I've looked everywhere online, can't find anything. The HP site is no help at all. Sure. they'll sell me a new printer but there is nothing useful I can find. All I need to know is does this thing require a power supply. I have the right cable but I can't find the power supply. Anybody have any knowledge in this? As always comments or flames welcome.
    Tnx,
    Dusty
  2. Posts : 1,670
    win 10
    hi according to this it should just plug into wall outlet. http://h10032.www1.hp.com/ctg/Manual/c04216096
  3. Posts : 10,485
    W7 Pro SP1 64bit
    It might depend on the serial number.
    Maybe early versions needed an external supply.
    Or maybe the newer versions need an external supply.
    I see documentation pointing to an external power supply...
    Printer Specifications for HP Officejet Pro 8610, 8620, 8630, 8640, and 8660 e-All-in-One Printer Series | HP® Customer Support
    ...and an internal power supply:
    https://store.hp.com/wcsstore/hpusstore/pdf/a7f65a.pdf
    Just plug it in - the flames might be literal.
