USB flash drive is not work
  1. Posts : 5
    My USB Flash drive was connecting to PC, that my windows 7 suddenly crashed.
    After that, my Flash never works right!
    Device Manager recognizes it slowly and its icon is shown on My Computer just as drive (without size) more slowly.
    Nevertheless, other software such as Disk Manager or any Recovery Soft or Command Prompt> diskpart will be frozen so I cannot handle it.
    I test it on other pc but the answer was same.
    My USB Flash drive is Silicon Power M01 USB3 16GB.
    Any advice would be great,
    thank you
  2. Posts : 5,656
    If it happens on different computers, it is somehow corrupt or faulty.
    Do you have any data on it you need to get or just want to make it work again?
    If you don't need data from it: You can try zeroing the drive with imageusb - Tools for OSForensics - ImageUSB - Write an image to multiple USB Flash Drives
  3. Posts : 5
    Give me any advice for anyone!
    Thx
    it's not work.
    With refreshing, It have been frozen too!!
  4. Posts : 5,656
    Try "USB Flash Drive Recovery For Repairing" - at the very bottom of page - SP / Silicon Power-High quality, Exclusive and Unique Leading memory storage brand
    This software is designed to repair malfunctioning USB flash drives. It will not recover any data/pictures stored on the device. All data on your drive will be permanently erased during the repair process. Please backup the contents of your drive before proceeding.
    Moreover, USB Flash Drive Recovery can disable the password on Win 7 for all Silicon Power USB flash drives. If you ever set the password for USB flash drive on Win 7, it might cause unrecognizable problem when you use the flash drive on different platform other than Win 7 OS. This tool can help you to disable the password and solve the problem directly.
  5. Posts : 5
  6. Posts : 5
    Problem still persisting!
    As i said, this software detect my flash and download recovery tool. but recovery tool is hanging to detect the flash.
    i update drivers, But nothing is changed.
    if i have way to prevent freezing, this issue will be solved.
  7. Posts : 5,656
    You can try HOME PAGE OF MISHA CHERKES
    Please note!
    This program can be very dangerous with the dull person, be careful. After performing full erasing or write/read test with pardidion or device all data will lost forever! Author does not responsible for usage of this software.
  8. Posts : 5
    my friends!
    thx for all
    i have tried all software
    i have attempted to solve it, but i could not.
    i used its guarantee, and replace it with new one
