Windows 7: USB High-Low sound every few minutes
13 Nov 2009   #11
wallyinnc
Windows 7 x64 finally!
Thank you, if you can let us know what the resolution is when you find it, it will also help others
15 Nov 2009   #12
brocksamson
Windows 7 64bit
fixed
OK, i figured it out. i did two things simultaniously but i havent had the problem since i did. the first thing is i cleaned out the mouse sensor. Not sure if it helped but what the heck. the second thing which i think actually fixed the problem is this. I went device manager (if you dont know how to get to it you can search for it) then i went to my Universal serial bus controllers. From here right click on the different contorllers and go to properties till you find what hub your mouse is under (mine was under generic usb hub). then go to the far right tab under power management. Under this a box will be checked that sets windows to turn off the mouse to save power. I unchecked this box and since then i have yet to have the problem. Hope this helps!
16 Nov 2009   #13
wallyinnc
Quote   Quote: Originally Posted by brocksamson View Post
Thanks for sharing the results. I never thought of that, I woudln't think it would be turning it on and off all the time.
High HDD access after boot for 10-20 minutes - CBS Persist log?
Hi all, I've noticed that my computer can sometimes be a little slow to boot and that the HDD activity spikes for 10-20 minutes randomly after every boot. If I wait awhile, it goes away eventually. Resource Monitor shows it to be Read access for a "CBS Persist" log...anything I can do to stop...
Performance & Maintenance
Annoying Echo Sound Every 40-60 Minutes?
For the past few weeks now this annoying echoy sound will play through my speakers every so often numerous times a day. Is there any way to track down certain sounds? Has anybody had this issue?
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
Bad sound quality ( high pitched, almost acoustic sound etc.) integrat
the sound is crappier than ever. I have this quality loss for a while but now is repulsive. Ive reinstall windows 7, reinstall relatek drivers, get ones specified by my motherboad manufacturer, tried the latest ones.... put power management at high performance...etc my motherboard ASUS -...
Sound goes off after 10 minutes, with screen
Hi All: I have searched everywhere, but can't find anything like this: here's my issue: Windows 7 turns off all sounds after about 10 minutes. Together with display. Now, here's my configuration: Windows 7, 64 bit pro. Dual display: dell 1907 and Samsung syncmaster
