Is their some reason I can't get you to post one of these?
Disk Management - Post a Screen Capture Image
The answer to your problem may be indicated there in that picture.
Sorry MarkP15 I didn't mean to get in your way.
I thought that 9 hours was long enough.
I also thought that maybe my request wasn't read or missed.
Your in charge.
Have a nice day.
Hi Mark
Following your instructions, after "Program File Dir" I get a box with
Modify
ModifyPrimary Data
Delete
Rename.
I select "modify" and alter
D to C
(I attached a screenshot but I couldn't post because it said i had too many characters. 44,020??)
Hi Jason,
If you try just uploading the screenshot on its own with no text that might work. Also, if you upload a screenshot from the Disk Management window, we could see what were are dealing with exactly.
Kind Regards,
Mark
Recovery partition should not be a primary partition. It should be hidden, no drive letter assigned. A utiltiy as powerful as Acronis Drive Director may be needed to quickly and effectively fix this. Again, recovery partition should be hidden, it should not have a drive letter assigned to it.
And, the 55MB OEM partition might be the SystemReserved partition, which Windows must have.
Hi Jason,
I think a good idea would be to remove the drive letter allocated to the reserved partition (D) so although the files are still there, they aren't recognised as a drive. To do this, right-click the drive that you want to change, and then click*Change Drive Letter and Paths, then click Remove and then confirm.
Kind Regards,
Mark
Mark, your idea is much easier to do! I thought OP indicated something amiss with diskmanagement -- I guess I read this topic wrongly :)
