hard drive partition problem
  1. Posts : 25,847
    Is their some reason I can't get you to post one of these?
    Disk Management - Post a Screen Capture Image
    The answer to your problem may be indicated there in that picture.
  2. Posts : 57
    He's busy doing it, give him some time...
  3. Posts : 25,847
    Sorry MarkP15 I didn't mean to get in your way.
    I thought that 9 hours was long enough.
    I also thought that maybe my request wasn't read or missed.
    Your in charge.
    Have a nice day.
  4. Posts : 19
    windows 7 home premium 32bit
       #14
    Hi Mark
    Following your instructions, after "Program File Dir" I get a box with
    Modify
    ModifyPrimary Data
    Delete
    Rename.
    I select "modify" and alter
    D to C
    (I attached a screenshot but I couldn't post because it said i had too many characters. 44,020??)
    Attached Thumbnails Attached Thumbnails hard drive partition problem-capture-2.jpg
  5. Posts : 57
    Hi Jason,
    If you try just uploading the screenshot on its own with no text that might work. Also, if you upload a screenshot from the Disk Management window, we could see what were are dealing with exactly.
    Kind Regards,
    Mark
  6. Posts : 19
       #16
  7. Posts : 2,774
    Windows 7 Professional 64-bit
       #17
    Recovery partition should not be a primary partition. It should be hidden, no drive letter assigned. A utiltiy as powerful as Acronis Drive Director may be needed to quickly and effectively fix this. Again, recovery partition should be hidden, it should not have a drive letter assigned to it.
    And, the 55MB OEM partition might be the SystemReserved partition, which Windows must have.
  8. Posts : 57
    Hi Jason,
    I think a good idea would be to remove the drive letter allocated to the reserved partition (D) so although the files are still there, they aren't recognised as a drive. To do this, right-click the drive that you want to change, and then click*Change Drive Letter and Paths, then click Remove and then confirm.
    Kind Regards,
    Mark
  9. Posts : 2,774
       #19
    Mark, your idea is much easier to do! I thought OP indicated something amiss with diskmanagement -- I guess I read this topic wrongly :)
  10. Posts : 57
    No problem Roland and thanks :)
