Problems after cloning C drive
Page 1 of 4 123 ... LastLast
  1. Posts : 52
    Windows 7 Ultimate 64bit SP1 w/latest updates
    I'm having problems after cloning my C drive (Windows 7 Ultimate 64Bit SP1).
    First I updated my BIOS because I'm looking to get a new video card and my motherboard needs an updated BIOS to support it. That went fine. After I installed the latest motherboard drivers (chipset, usb 3.0, etc).
    Then I decided to clone my main C drive and my second D drive. I used an external docking station (StarTech SATA Duplicator Hard Drive Doc) which is supposed to make a bit for bit copy. My original drives were Intel X25-E Extreme 64GB. The new drives are SAMSUNG 850 PRO 256GB.
    D drive first (I have some software installed on it). Seemed to work fine. Then I did my C drive, and this is what happened.
    When I first booted up with it, windows ran a quick repair, restarted, and it booted fine. Everything looked good. I restarted a few times, ran a few programs, no problem.
    Then I booted into safe mode because I was trying to delete a folder that was locked. Right before booting into safe mode it ran chkdsk and a bunch of stuff flew by. Fixing orphan file ..... It went fast so I couldn't see. After that it booted into safe mode fine and when I rebooted it was fine.
    Then I tried windows update and got Error 0xC80003FB. I ran the windows update repair tool and it fixed a bunch of errors except one. Still wouldn't work.
    So I ran a chkdsk on the C drive. Right click, properties, tools, check now and i checked both boxes, restarted and let it run. It ran through restarted and now windows update works.
    Next problem, when running Itunes or Photoshop (only ones so far) I got a message that dnssd.dll is either not designed to run on windows or it contains an error. After clicking ok the programs ran. I couldn't find a solution so I copied this dll from another windows 7 machine to mine, and the error went away.
    Now when opening itunes, it works fine but if I click on preferences it takes forever for the preferences to come up. If I click before, it freezes. I uninstalled and reinstalled itunes but still have that problem. Also, when I open Filezilla (an FTP client) I get error messages. It seems to work and I can connect to the FTP but I get errors if I go to HELP and ABOUT, or if I try to import settings, etc. I haven't tried reinstalling yet, but I fear it won't fix it.
    It also seems the windows recent and frequent programs is not working. When I used to right click on the taskbar icon for an open folder it would show a list of frequent folders I opened, and I could drag a folder onto it to add it to the pinned list. Now it only shows windows explorer, pin this program, and close. I can't add anything to it.
    Any ideas? Is the drive bad? Did something get corrupted? I'm afraid what other problems I may have. Sorry for the long post.
    Thanks.
    System specs:
    --OS: - Microsoft Windows 7 Ultimate (64 bit) SP1 with latest updates.
    --Monitor: - Dell UltraSharp U3011 30-inch Widescreen
    --Case: - COOLER MASTER HAF X RC-942-KKN1 ATX Full Tower
    --Motherboard: MSI Big Bang-XPower LGA 1366 Intel X58
    --CPU: - Intel Core i7-980X Extreme Edition Gulftown 3.33GHz
    --CPU Cooler: - CoolIT Systems VAN-R120 Vantage A.L.C. Liquid Coole
    --Power Supply: - CORSAIR Professional Series AX1200 1200W
    --Sound Card: - Creative Sound Blaster X-Fi Titanium Fatal1ty
    --Video Card: - EVGA SuperClocked 015-P3-1582-AR GeForce GTX 580 (Fermi)
    --Memory: - G.SKILL Ripjaws Series 24GB (6 x 4GB) 240-Pin DDR3 SDRAM
    --Memory Cooler: - G.SKILL FTB-3500C5-D Fans
    --1st Hard Drive: - SAMSUNG 850 PRO 256GB SSD
    --2nd Hard Drive - SAMSUNG 850 PRO 256GB SSD
    --3rd Hard Drive: - Western Digital VelociRaptor WD1000DHTZ
    --4th Hard Drive: -Seagate Barracuda XT 2TB 7200 RPM 64MB Cache
    --1st Optical Drive: - LG WH10LS30K 10X Blu-ray Burner
    --2nd Optical Drive: - LG WH10LS30K 10X Blu-ray Burner
    --Keyboard/Mouse: - Logitech MX 5500 Revolution Bluetooth Cordless Desktop
    --Card Reader: Nippon Labs Delux 3.5" Internal Card Reader/Writer
    --Speakers: - Altec Lansing ADA995 5.1 surround speakers
  2. Posts : 21,004
    Just very quickly I personally would re clone that drive/s and use Macrium free to do it as I find it is the best cloning software. I say this because I think as you said it yourself that the drive may have become corrupted or rather the transfer of data got corrupted during the cloning process.
    Macrium Reflect Free
  3. Posts : 52
    Do you know if this will also clone the hidden 100mb windows partition as well? The reason I used the docking station is that it is suppose to be a hardware bit for bit copy of the drive, with less chance of problems from cloning using software. So I'm not sure why it didn't work.
  4. Posts : 4,751
    It will clone everything that you tell it Macrium to, including the System Reserved (100 mb), but you have to mark each partition that you want copied. I agree that Macrium is the program to use. Also could you post a Screen shot of your Disk Management so we can take a look at it. Disk Management - Post a Screen Capture Image Be sure and widen the columns so we can read all of the print. == One more question just to clarify. Are you saying that the clone does not work now or the original does not work?
  5. Posts : 52
    Right now I am trying the clone again with the docking station, just to give it one more try.
    I have not put the original back in the computer yet, but the original was working fine. I'm only changing drives to get more space, and thought it would be nice to get a performance boost. Nothing was wrong with the original.
    The cloned drive would boot, but I started having problems (as I explained in the original post). So something went wrong. If this second clone attempt doesn't work then I guess I will look into Macrium. I assume I can keep my other drives plugged in while using Macrium? I can connect one drive through the esata docking station of my other computer, and I guess plug one in internally to the motherboard. And then clone.
    I'll let you know how this second docking station clone attempt works.
    Thanks.
  6. Posts : 52
    Well it's doing the same thing after retrying the clone with the docking station.
    When I first booted it ran a windows repair again. Then when starting into windows it loaded the drivers for the samsung drive, successfully. Restarted and booted normally.
    I didn't get that dll error when opening itunes but opening preferences still takes forever. Filezilla still shows errors. The jump list/favorites are not working. And windows update is giving the error again.
    I've read other people using this docking station and having no problems. Unless there is something wrong with the dock or maybe something wrong with the drive. Here is a screenshot of disk management.
    https://www.sevenforums.com/attachmen...1&d=1447625587
    I guess I'm going to have to try a software option and see if that makes a difference.
    Attached Thumbnails Attached Thumbnails Problems after cloning C drive-disk-management.jpg
  7. Posts : 52
    So I put my old C drive back just to check things and it still works fine. No problems with itunes preferences, no errors with Filezilla, no errors running windows update.
    So I don't know if my computer/windows just has a problem with the new/different drive, if there is a problem with the docking station, or if the SSD is defective. I'm almost inclined to buy another SSD and give it a try.
    Unless anyone has any other suggestions. I think I'm done for tonight. Will have to wait until next weekend to try again. If no other suggestions then maybe I'll try installing Macrium on my backup computer and trying to clone from there. Or if I'm ambitious maybe I'll order another samsung drive and try the docking station with that first.
  8. Posts : 21,004
    If you think the docking station method might be the problem then try using a USB to SATA adaptor - I use one all the time so I don't have to disassemble anything. They are cheap enough and a very handy tool for doing any work on a drive outside of a working machine.
    Attached Thumbnails Attached Thumbnails Problems after cloning C drive-usb-sata-adaptor.png
  9. Posts : 52
    I have one of those but the docking station is an external 2 bay drive that does hardware duplication without being connected to the computer. It has it's own duplicator. I can also connect it to the computer through esata to connect the drive to the computer.
    But if I wind up using software then i can use the docking station as the external connection.
    I've also heard good things about acronis. Do you think macrium is better than acronis?
    Thanks.
  10. Posts : 4,751
    Your Disk Management looks OK with the exception that the System Reserved should not have a letter. You should remove the Z:
