Multi Monitor environment resets to over under setup not side by side
So my issue is that when I log into my computer it will some times (not all the time) revert from a side by side multi monitor setup to a over under setup. Like if you go into screen resolution settings I will have it set to monitor 1 on the left, and monitor 2 on the right, then when I lock the computer and then log back in, it will have monitor 1 positioned over the top of monitor 2.
I'm thinking there is possibly a default that it keeps going back to, but I'm not sure where I would look for that, other than the screen resolution settings. Another possibility for the origin of this problem could be Microsoft User Experience Virtualization Agent, which we have installed on all our computers here to synchronize the various setting we have connected to our profiles. It looks like UEV might synchronize monitor layout settings, and with that it could be some how defaulting on an over under set up. Overall I am unsure of what to do about his.
Any one have any ideas?
