USB 3.0 port does not recognize flashdrive + another problem (explaine
  1. Posts : 119
    the title says it. I installed win7 on my new configuration, downloaded latest drivers from ASUS website, then downloaded SP1 and more than 230 (!) important updates via WU.
    There are two 2.0 and two 3.0 ports on my Fractal design R5 front panel. One of the two USB 3.0 ports is not working, meaning that it does not recognize my San Disk 32GB 3.0 pen drive (though Device Manager as you can see, does recognize it). Even when I plug it on the other (working) 3.0 port I got generic notification that it can perform faster if I connect it to 3.0 port (!). Obviously, something is not working properly. I checked the USB drivers one by one via Device manager and it says that the drivers are up to date.
    Then I checked Device and printers via Control Panel and I noticed yellow triangle notification on my PC (see attach.) I checked Other device on DM which also has yellow triangle notification and it says that Windows can not find driver for that unknown device.
    Any clue to what might cause this..?
    Attached Thumbnails Attached Thumbnails USB 3.0 port does not recognize flashdrive + another problem (explaine-12.jpg   USB 3.0 port does not recognize flashdrive + another problem (explaine-13.jpg
  2. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
    No telling if this is true or not but a few reviews say this model does not like win-7 :/
    SanDisk Extreme 32GB USB 3.0 Flash Drive Model SDCZ80-032G-A46 - Newegg.com
  3. Posts : 119
    It is beyond help, obviously :/
  4. Posts : 20,583
    Well I have a pny usb 3 and it works well so it's likely just the manufacture that is lazy :)
