Serious hard drive problem
So I tried turning on my Asus G73JH laptop today, and I got the Asus screen followed by just a black screen... it stays that way indefinitely. Tried rebooting many times without the battery to no avail. I can access bios, and already tried resetting to optimized defaults but it did nothing. So I booted up with knoppix to try and diagnose the problem... My top priority is backing up everything on my hard drive to my external one, cause I have a ton of extremely important work & school stuff on there. However it won't mount my HDD (sda2) for some reason. Here is the error I get
Error mounting system-managed device /dev/sda2: Command-line `mount "/media/sda2"' exited with non-zero exit status 13: ntfs_attr_pread_i: ntfs_pread failed: Input/output error
Failed to read hiberfil.sys: Input/output error
Failed to mount '/dev/sda2': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details
How can I find out exactly what the problem is? Is there any way I can run a chkdsk or system restore? Can data recovery software salvage an I/O'd disk? I've been thinking about disassembling the laptop, cleaning it out, and seeing if everythings connected properly. What else can I try?
Any help is welcome
