Help with Front Panel/Power Button Connector
Hello! Recently, I transferred my Dell Motherboard (From an Inspiron 560) to a new Rosewill Challenger-S case. All of that went fine and dandy but now I'm facing another problem: I don't quite know where to plug up the cables from the case's front panel (power switch, reset switch, HDD LED). I found a port on my motherboard labeled "Front Panel" which matches the ports, but one is missing like normal front panel connectors, and the cables only take up 6 out of the 9 pins. So the real question is, where do you plug up the cables, or do you even put them in that spot?
Sorry if that sounded really nooby,
JaxDrumm
