RAM problem help me?
  1. Posts : 56
    Windows 7 Ultimate 32bit
    I have one problem
    I have motherboard P5VDC-X Dual Channel (DDR, DDR2)
    I have 2 pieces RAM 2X1GB DDR2
    If i put 2 pieces on my mobo my screen freezes often
    Yesterday i take off one piece of RAM outside, take off CMOS battery and put again battery and turn off pc and seems screen freezes dissapear
    My question is did will something need to set in BIOS or somewhere?
    I have test my two pieces RAM with memtest and no errors
  2. Posts : 56
    + look :/
  3. Posts : 1,436
    Windows 7 Home Premium
    Hi Ace,
    in what slots do you insert the ram sticks in?
    /Boris :)
  4. Posts : 56
    if mean for this
    In ddr2 slots :)
  5. Posts : 1,436
    AceDuk said:
    if mean for this
    In ddr2 slots :)
    What I meant was that on your motherboard there are 4 slots, 2 are blue and 2 are yellow.
    Maybe you have to put two sticks into the blue slots and two into the yellow slots?
  6. Posts : 56
    BorisTheAnimal said:
    AceDuk said:
    if mean for this
    In ddr2 slots :)
    No blue slots are empty, just one RAM in yellow slot
  7. Posts : 1,436
    AceDuk said:
    if mean for this
    In ddr2 slots :)
    Okay but how do you have it setuped?
    Like with some motherboards there is a sequence when putting in ram.
  8. Posts : 56
    i haven't setuped
    Did something need to be setuped?
  9. Posts : 56
    any suggestions?
  10. Posts : 13,576
    Both sticks should be in the same colored slots.
