My Monitor goes to sleep after 10 minutes, screensaver none, power....
  1. Posts : 6
    windows 7 professional x64
    hello i am new to the forum, Well i am getting really frustrated that my monitor goes to sleep after 10 minutes of inactivity, but my computer still runing,video still playing, music still playing, just my monitor decided to go to sleep for no reason, and i have to move my mouse to get it wake up again. i have set my screensaver to off, and power option to never, and it is still happening. i might not be the only one here having the same problem, if anyone have any solution that could help me out please do , i will really appreciate it ;c
  2. Posts : 1,670
    win 10
    Hi welcome to the forum
    what do you have your monitor to do after a certain time? go to control panel power options on left hand side of screen choose when to turn off the display
  3. Posts : 6
    its set to never alreaady, but still getting the same problem
  4. Posts : 6
    bump
  5. Posts : 7,115
    advanced
    Hi Axely,
    I use high power option, with these options, give them a try
    Roy
    Attached Thumbnails Attached Thumbnails My Monitor goes to sleep after 10 minutes, screensaver none, power....-power.png
  6. Posts : 6
    hmm weird, i do not have that option "multimedia setting"
  7. Posts : 7,115
    high
    Did you look at the
    HIGH performance section, of power options, NOT balanced.
    Roy
  8. Posts : 6
    yes i did
  9. Posts : 6
  10. Posts : 1,670
    win 10
    Can you try another monitor or if monitor has another type of input try that.
