External WD 2TB Hard Drive Problem (corrupted)
Good day friends, I have encountered a problem with my WD My Passport 2TB 0748 external HDD. I last used/connected it to a computer about 2 months ago and it was perfectly fine. 2 days ago, I connected it and I can't access it anymore.
In My Computer in Windows 7 (or This PC in Windows 10):
It lists it as Local Disk G: (but it doesn't show the bytes used and bytes free)
In device manager:
there is a yellow exclamation point on the name of this HDD under both portable devices and disk drives.
In Disk Management:
It lists the volume as 2TB but doesn't list whether how much is being used and how much space is free
Other symptoms:
- I can't seem to open some apps when I connect this HDD to the computer but they will literally open up the second I plug out the HDD
- I also can't get the "remove safely" message to work so I plug the HDD out now
I tried this HDD in 2 computers (1 windows 10 and 1 windows 7) and all symptoms are the same.
Is there a way to recover all of my files? or at least as much as possible of my files?
EDIT:
I saw this thread and I have the same problem (and exact same 0748 model of hdd)
External Hard Drive: detected but does not show up in folder
But I don't have any virtual cd drive and I already uninstalled Itunes and the problem still persists. I also tried installing the SES driver like that user but same problem still.
I am not very familiar with extremely technical terms related to software/computers, so I apologize in advance.
Please help. Thanks.
