@maxseven, that won't work rather it can't be made to work.
a. WD My Passport is hardware encrypted and decrypted by the electronics inside the enclosure. If the drive is taken out and tried and assuming that the HDD itself is OK, what all you will get is the encrypted data which will be absolutely useless garbage.
b. In most of the WD external drives the SATA to USB bridge ( that incidentally includes the encryption and decryption chip) is integrated with the hard drive and hence the HDD itself may be inseperable.They are bonded together, live together and die together - as for as the user is concerned. :).
In case of failure of the electronics inside the enclosure, only WD authorised - patronised - data recovery partners can recover the data since only they have the knowhow to decrypt.
In case the electronics has not failed, then any data recovery attempt has to be made without separating the electronics from the drive to be able to get the decrypted data.
