cAPS LOCK aND shift key actinG sTRange
  1. Posts : 2
    windows 7 x64 pro
    as you can See HeRe ClEARLY i am typING IN ALL LOWER CASE> CAPS LOCK AND SHIFT Key hAVE BEEN ACTING STUPID SINCE monDaY morninG> I TESTED 2 OTHER KEYBOARDS, wired and wiRELESS WItH SAME RESULTS> CAN ANYONE HELP ME WITH THIS NIGHT MARE? Ran sfc> i have no restore points to turn back to>
    gracious thanks
  2. Posts : 21,004
    Hello and welcome trinity mate for starters I would be running these
    Disk Check < if necessary include the /f and /r in the command line as per Option2 < in safe mode
    and if these pan out ok then run these
    SUPERAntiSpyware | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware!
    Malwarebytes | Malwarebytes Anti-Malware Premium
    AdwCleaner Download
    delete any rubbish found with the malware scans
    (NB If one is running Kaspersky security it may rant about ADW - just ignore it or disable Kaspersky while the ADW is being used)
  3. Posts : 45
    Windows 7 Home x64
    I got a call from a guy having problems with his mouse. He tried another but with the same issues. So I instructed him to delete the drivers from device manager and restart the system - it cleared out the problem. So just go to device manager and uninstall any keyboard drivers and restart system. Worth a shot.
  4. Posts : 6,330
    Does this mean you ran SFC and it found errors that were not fixed ?
    If you do have errors, did you run SFC up to 3 times with a reboot after each run ?
  5. Posts : 21,004
    As David has asked and I nearly always do the chkdsk with my machines too especially if the SFC doesn't come up with a fix or issue to be fixed and I would also do those malware scans too they don't take long and would eliminate anything coming from that direction.
