Not enough space error using Disk Management to shrink volume
There is pretty much space on C drive, but it does not allow me to shrink. Any suggestion will be appreciated.
Hi and welcome.
Can you post a screen shot of your Disk Management. We can provide better assistance if we can see what we are dealing with.
The reason why Windows won’t let you shrink the volume is because there are immovable system files at the very end of the volume, as this screenshot from utility shows us. there are multiple things you could try to work this around.
1. Run the Disk Cleanup Wizard, making sure to remove the hibernation file and all restore points.
2. Disable System Restore
3. Disable the pagefile ( Open up System in Control Panel, then Advanced System Settings \ Advanced \ Performance \ Advanced \ Change \ No Paging File.
4. Disable kernel memory dump. In the same Advanced Settings, go to Startup and Recovery \ Settings and then change the Write debugging information drop-down to “None” to disable the kernel memory dump.
5. Disable Hibernation mode in your power options \ advanced power options screen.
Reboot the machine, and then delete your c:\pagefile.sys file, following these instructions in one set.
more details, see shrink volume not enough space
