My external hard drive is always flashing and will not work.
  1. Posts : 2
    Windows 7 Home Premuim 32bit.
    I have a Toshiba external 1TB hard drive. It shows up as Local Disc in computer but clicking on it make the Windows Explorer box not respond. I have tried uninstalling/updating the the driver in device manager however it just endlessly uninstalling/updates. I have tried using chkdisc in cmd however nothing happens. I have tried unplugging everything except the external drive however this does nothing. I have tried using disc manager however it gets stuck at "Connecting to Virtual Disc Service". I have tried several Partition Recoverytools and all of them do not work. I cannot disable it in Device Manager. Clicking populate on the Volumes tab of the properties causes the properties to not respond.
    Please help. I have tried everything that I could find.
  2. Posts : 2,774
    Windows 7 Professional 64-bit
    "...Connecting to Virtual Disc Service.." I don't understand what a Virtual Disc Service is.
    What does this ext HD do in another computer? And, you have already tried Safe Mode on this computer, correct?
  3. Posts : 708
    Windows 7 x64
    Try to connect the ext HDD to another USB port.
    In normal case, USB driver is standard, no need to updates.
  4. Posts : 2
    RolandJS
    I have just tested it on another computer. It does not work. Yes I have tried safe mode, same thing.
    Eric3742
    I have tested it on several different USB ports.
    Please help!
  5. Posts : 1,442
    Windows 7 Professional 64bit
    I also ran into an issue where the disk manager would get stuck at "Connecting to Virtual Disc Service".
    Run SFC, following this tutorial and try disk manager again.
  6. Posts : 708
    Windows 7 x64
    From my experience this Toshiba ext HDD is not from Toshiba itself.
    I went to Toshiba Service center as my brother's laptop had hard disk failure.
    At the same time, i ask the staff about Toshiba HDD (which i showed them).
    The service staff told it is not from them, as Manufacturer &or Distributor.
    They did replaced another HDD on the Toshiba laptop, as still in the warranty.
    I did had some HDD (internal & external), and some (especially the ext HDD) cannot be detected.
    When i attached to the USB port, the issue is the same as yours.
    Sadly to say, the ext HDD could have failed.
    I do have an external HDD and is no longer work, no matter what i did.
    Hence i avoid buying Toshiba HDD, whether internal or external.
    The only HDD i accept are mostly; Samsung, WD.
    Edit: Not buying from any Retailer.
  7. Posts : 2,774
    Guys, Gals, what is Virtual Disc Service - in this context?
  8. Posts : 1,442
    When you click on disk management.
    Attached Thumbnails Attached Thumbnails My external hard drive is always flashing and will not work.-vds.png
