i got mine to work at last just unrared to aifolder on desktop set compat mode for vista then went into aifolder then acpi64folder ran the asacpilns then ran the main setup hope this works for you:)
i have a sony vaio vpceb 190x with a windows 7 ultimate.after instaling VAIO control centar i get a message that the battery is not compatible ,press ok to hibernate....
If i disable the acpi control method in device menager i dont get the error mesage but the computer does not have control over...
I have Toshiba satellite L300 upgraded from Vista to Windows7 which now freezes on windows welcome screen...only if the charger is plugged in at start-up. NO problems on battery alone.No problems in safe mode. If running on battery alone all is fine until plugging in charger and screen will freeze...
Hello,
Yesterday I installed the Windows 7 Professional RTM from MSDNAA on my Compal JHL90, before I installed the RTM I used the RC since it came out. With the RC I had single problems, so I expected to have no problems with the RTM aswell. Unfortunately I do have a problem.
I have the...
I had installed Seven on my Dell Dimension 4400.. everything was all right and I was working successfully with that operating system but I had to upgrade my BIOS and after that it shows me error when I try to start system: 0xc0000225 (Windows failed to load because the firmware is not ACPI...
Hello everyone. I am trying to install Win 7 but i get an blue screen and error message says:
"...The BIOS in this system is not fully ACPI compliant. Please contact your system vendor for an updated BIOS.
Technical information:
*** STOP: 0x0000000A5 (0x0000000000001000, 0x0000000000000000,...
