Can someone help me with this? If I go back to the suggestion to change my active drive, how do I verify the system files are on the drive I'm changing to?
Any other ideas on how to fix this?
Hi HairfallingOut,
making changes to problem devices will proboly not work, as there allready in an unstable state.
post a copy of your faulty devices, marked with ! or small black down arrow and problem devices.
rolling back from 10 is causing problems.
Did you have any usb's plugged in when you did ??, hope not
Roy
Thanks Roy. I'm not sure what you want me to post. Please also note that I had to reformat my hard drive because of the Windows 10 issues, so Windows 10 shouldn't be causing problems now, right?
