External Harddrive problems!
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 20
    windows 7 64bit
  2. Posts : 20
    windows 7 64bit
       #12
    Hi Jumanji,
    Sorry about the attachments earlier.
  3. Posts : 20
    windows 7 64bit
    I'm not sure about partitions. I did not actively create any.
    The advertised capacity was 160gb
  4. Posts : 20
    windows 7 64bit
       #14
    I also used EASEUS and could see all my files in the search.
  5. Posts : 20
    windows 7 64bit
       #15
  6. Posts : 7,055
    Windows 7 Home Premium 32 bit
       #16
    OK, I shall give the instructions tomorrow. It is already late for me today considering I was awake till 2AM today..
  7. Posts : 20
    windows 7 64bit
       #17
    Thank you so much Jumanji...I look forward to hearing from you
  8. Posts : 7,055
       #18
    Plug in only your faulty drive ( Make sure you have no other external HDD/Flash drive/ Card Reader/USB hub/Printer with USB ports is plugged in)
    Run TestDisk.
    1. [No Log] - Enter
    2. Highlight/Select your 160GB Disk ( Select Disk and not drive with drive letter) [Proceed] Enter
    3. Highlight/Select [Intel] Intel/PC partition Enter
    4. Highlight/Select [Advanced] File System Utils Enter
    Post the screenshot of the 5th screen that appears. Further Instructions will depend upon what appears in it. Close TestDisk and wait for it.
  9. Posts : 20
    windows 7 64bit
       #19
  10. Posts : 7,055
       #20
    My trial drive Seagate GoFlex 750GB seems to have breathed its last. The screenshots at post#10 which I took yesterday night was the last of it. I had left it connected to my PC after taking the screenshots. Today it is not there. Now I have to buy another drive exclusively for my experiments.
    Anyway, coming to your drive, [Boot] is highlighted. Press Enter and then post that screenshot. We will know the status of your boot records.
