Windows 7: CPUID HW Monitor - Does this look like a power supply issue?
08 Dec 2016   #1
sportsguy
Windows 7 Professional x64
My cpu with an INTEL water cooling system shows 170-180 degrees with no applications open and the virus scanner running over night. . . These voltages don't look right, so is my motherboard dying or is the power supply dying or something else?
see attachment
08 Dec 2016   #2
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
You can not trust that software at all, check the bios, and install Core Temp.
Get rid of HW Monitor.
Just open up the Bios and watch the cpu temp, it`s the only true reading you`ll ever get.
Program to monitor Power Supply
I am starting to think I may have a power supply issue and none of the programs I use seem to monitor it correctly or the power supply is bad. I have been using TOverclocker (came with my Biostar MB), Speccy, Everest, HWinfo64, HWinfo32 and SpeedFan. None of these give me consistent measurements...
Hardware & Devices
Issue with new power supply
The power supply on my PC works, but the fan is making an intermittent "tic-tic-tic" noise, so I decided to replace it. After installing the new power supply, I got nothing. No LEDs, no fan, no hum... nothing. So I pulled the new power supply out, manually jumped pin 14 to ground, and it fired...
Hardware & Devices
Power Supply Issue
Have a strange issue with my computer. Started recently, when shut down, power switch will not turn on computer. If I pull the powercord for 20 secs or so, it will power on fine. Tried a new power cord, same symptoms.... Is this a failing PSU or motherboard issue?
Hardware & Devices
Power Supply Issue
Wasn't sure where to post this (slightly off topic but I figured someone on here would be able to shed some light on this). I have an HP DV7-4285DX laptop, the machine runs Windows 7 Home Premium and is performing quite well after a good weekend of "De-OEM'ing" (uninstalling the crap it came...
Performance & Maintenance
Possible power supply fan issue w/ Win 7
I haven't kept up with power supply technology at all, on my old PCs that ran Win 95 thru XP, I generally had 250W-450W power supplies that were pretty noisy. The power supply fan ran all the time, and expelled quite a bit of warm air. On my new PC with Windows 7, I have a "700 watt" power...
Hardware & Devices
