Windows 7: How do I fix a drive letter issue after doing a startup repair?
25 Feb 2017   #11
Barman58
Windows 10 Pro x64 x3, Ubuntu
This old thread may explain some of what is involved Converting a dynamic disk to basic without data loss
25 Feb 2017   #12
cheaterslick
Windows 7 Pro 64bit
Quote   Quote: Originally Posted by Barman58 View Post
The major problem now is that however this has happened it has likely deleted all or any data that was on the disk before the conversion.
Well the good news is I did backup that disk beforehand.
And
I can still actually go into the disk and still see the data is still in there.
Assuming you have a backup of the contents of the D: drive you should be able to wipe the disk, reset it to a simple disk, reformat to NTFS, and restore your data.
How do I reset it to simple disk?
And when I right mouse click the drive to try and format the drive, it says I can't do it because it's dynamic.
What else can I do?
25 Feb 2017   #13
Barman58
We have a Tutorial for this ...
Convert a Dynamic Disk to a Basic Disk
There was also information on the link I posted above about changing a setting to make the dynamic disk visible or more precicely revert to a standard disk by manually editing the MBR - Converting a dynamic disk to basic without data loss
Although, as you have data visible on the disk you may want to try one of the numerous free programs that purport to do the conversion without loss of data first
The one suggested in the tutorial no longer offers this in the free version but a quick google should find a few options ( I have the Paid version of Partition Wizard so cannot recommend any particular program) but as you have your backup it should be OK even if it does not retain data
25 Feb 2017   #14
cheaterslick
Windows 7 Pro 64bit
Actually, what I'd like to do now is switch out the D: drive with a new, bigger HDD drive. I can do the data recovery to it later.
In fact, this is what it looks like after installing the new drive. Notice I haven't done anything to it other than physically putting it into it's new slot.
The boot partition and C: are still set to Disk 1 and not Disk 0 like before. I don't think it will let me change it.
So the situation is different, now. What would I need to do in this particular case?
25 Feb 2017   #15
RolandJS
Windows 7 Professional 64-bit
What happened? Post #1 showed a pic that included: ( D: ) 100 MB NTFS Healthy (Active, Primary)
That was the D, that was the partition I suggested dropped the drive letter from. Is that not the partition used by Windows 7 to boot and load? I just now noticed: that particular partition was on Disk 1, not on Disk 0. How did a Windows boot/load partition did onto Disk 1 and not be on Disk 0?
26 Feb 2017   #16
Barman58
The disk numbers are set by the physical location, assuming you have Six SATA ports on the motherboard numbered One to Six the the drive plugged into the first port, (Port One) will show up as Disk 0. This is based on windows which starts numbering disks from 0, (some other applications e.g.. Partition Wizard actually start numbering from 1 so would show a different number from Windows own Disk Management).
So basically if you wish to have your System drive showing as Drive 0, the first drive, you need to physically connect the SATA connections to the drives in the order you want. (this will not actually make any difference to the running of the system but I will admit it's slightly easier on the user if the drives are in an order that is logical)
26 Feb 2017   #17
cheaterslick
Windows 7 Pro 64bit
With popping in the new drive, we're no longer talking about basic vs. dynamic anymore. Switching to a bigger, faster storage HDD was something I was thinking about doing anyway, so this was coincidentally also a good opportunity to do it.
Well it's a laptop so it can only connect one way anyway, unlike a desktop where I might have extra SATA connectors tied up inside the CPU case that are unused.
It looks like it's stuck in the order that it is and won't allow me to change it under the circumstances.
So you're saying I can leave it in the Drive order that it is now and it won't affect anything?
If it's ok to leave Disk 0 and Disk 1 like that, then what steps would I need to do next in order to activate this new Disk 0 drive?
26 Feb 2017   #18
Barman58
Yes laptops can limit your options.
You could disconnect the existing Drive 0 and reconnect to the other SATA connection and then add the new drive to the freed up connector, ( if they will fit), which should show the windows drive as Drive 0 and the new drive as Drive 1 but as It will work the same which ever order they show in the drive management so it's just personal choice.
The only prep you should need for the new drive 0 is to ensure it is partitioned how you want it. The default would be a single partition, and that it it formatted, normally these days the default is NTFS. For general use for data storage these defaults are fine. There is also the question of the low level files system MBR or GPT - for a data drive I would simply use what ever is on the drive as default - unless you wish to use it to run multiple Operating systems or the drive is larger than 2TB and you wish to utilise a single partition, (with large drives the GPT system is normally used to present the drive as a single partition as it sells Drives)
26 Feb 2017   #19
cheaterslick
Windows 7 Pro 64bit
Well that's the problem. It's only got the one SATA HDD bay and that's used as the D: drive for storage, which is the drive in question that we've been talking about here. The boot partition and the C: drive is on an mSATA SSD connector at the other side of the laptop. There's no space (or standard SATA connector) for another HDD so I don't think doing what you're proposing would work.
Since it seems to boot just fine (even though it's out of logical order), would there be any point to try and switch them? From Drive 0 to Drive 1 and vice-versa? I don't want to make the problem any worse than I have to.
It's a new 750GB WD ScorpioBlack drive.
Looking at my picture in post #14 - so go ahead and Initialize the Disk to Drive 0 as a MBR partition?
Then format it to NTFS?
And then assign the D: letter to it?
Do those steps in that order?
26 Feb 2017   #20
Barman58
Yes that order seems fine :)
Drive letter issue in Windows 7
Hi, I have two (2) Windows 7 Ultimate installations on my PC. I have two installs because I need one particular setup for video editing resource purposes. In boot #2 I have following letters: (For Video Editing) C - Data and FSX (For General data and Flight Simulator) B - The Boot drive for...
Hardware & Devices
Drive letter changed at startup
Hello, I have a wierd problem that i don't understand: Becouse of an unfortunatly accident (whici i don't yet understand), my drive letters change, my C: became D, and so on, and logically, the windows couldn't start becouse it didn't know where windwos was. What was strange, using acronis...
Hardware & Devices
Removable devices USB port drive letter issue
I have two monitors that have ports for USB and memory card built into the side of them. When the monitor is plugged into the CPU they are assigned drive letters and become available for use. The problem I'm having is that they are sometimes interfering with my network assigned drive letters...
Hardware & Devices
Startup Repair issue?
Here is the story, a computer got a virus, and was beyond repair, So we went for a clean format. The computer was for some reason unable to boot from the windows disk, or any disk for that matter. So i hooked up the hard drive to another motherboard, and installed windows 7 from there. And hooked...
Installation & Setup
Change drive letter using Repair install?
Had an XP dual boot with Win7 RTM. Deleted XP C: drive and moved RTM D: drive over into it's space. I would like to keep and license this installation using retail Win7 Ultimate Signature Edition received with party pack. Is there a way to change the Win7 D: drive to C: by running a repair...
