Windows 7: How do I fix a drive letter issue after doing a startup repair?
27 Feb 2017   #21
cheaterslick
Windows 7 Pro 64bit
Well everything seems to be up and running. If there are any other problems, I'll open a new thread and refer to this one if need be.
Thanks to all.
Drive letter issue in Windows 7
Hi, I have two (2) Windows 7 Ultimate installations on my PC. I have two installs because I need one particular setup for video editing resource purposes. In boot #2 I have following letters: (For Video Editing) C - Data and FSX (For General data and Flight Simulator) B - The Boot drive for...
Hardware & Devices
Drive letter changed at startup
Hello, I have a wierd problem that i don't understand: Becouse of an unfortunatly accident (whici i don't yet understand), my drive letters change, my C: became D, and so on, and logically, the windows couldn't start becouse it didn't know where windwos was. What was strange, using acronis...
Hardware & Devices
Removable devices USB port drive letter issue
I have two monitors that have ports for USB and memory card built into the side of them. When the monitor is plugged into the CPU they are assigned drive letters and become available for use. The problem I'm having is that they are sometimes interfering with my network assigned drive letters...
Hardware & Devices
Startup Repair issue?
Here is the story, a computer got a virus, and was beyond repair, So we went for a clean format. The computer was for some reason unable to boot from the windows disk, or any disk for that matter. So i hooked up the hard drive to another motherboard, and installed windows 7 from there. And hooked...
Installation & Setup
Change drive letter using Repair install?
Had an XP dual boot with Win7 RTM. Deleted XP C: drive and moved RTM D: drive over into it's space. I would like to keep and license this installation using retail Win7 Ultimate Signature Edition received with party pack. Is there a way to change the Win7 D: drive to C: by running a repair...
