Windows 7: How do I fix a drive letter issue after doing a startup repair?
24 Feb 2017   #1
cheaterslick
Windows 7 Pro 64bit
Hello,
I installed a new Samsung 850 EVO mSATA drive the other day and when I restarted it, it reported that a bootfile was missing and so I pulled out my OEM OS disk and did a startup repair from there. It repaired the boot file and I was able to log in, but then it changed the drive letters as you can see in the attachment below.
As you can see, Disk 0 is now Disk 1 and Disk 1 is now Disk 0 switching the order. Windows also assigned the boot partition the drive letter D: where there was no drive letter for this before.
Although I can now boot into the system just fine, these drive letter changes are playing havoc with certain programs that I run.
If I can find out how to change these drive letter settings without breaking the bootfile or damaging a drive, I'd really appreciate it.
Thank you
How do I fix a drive letter issue after doing a startup repair?-dsk_manage.png
24 Feb 2017   #2
johnhoh
Win7 pro x64
right click on each drive and select "remove" (to remove letter) or "change drive letter and path" to change letter
when wanting to just swap two drives you need an interim placeholder, like say if D and C are reversed, you change D to Z, then C to D, then Z to C
24 Feb 2017   #3
cheaterslick
Windows 7 Pro 64bit
Quote   Quote: Originally Posted by johnhoh View Post
Can I leave the D: blank and have no drive letter assigned for that space?
And would that switch everything from Disk 1 to Disk 0 and vice-versa?
I want D: to have no dive letter
I want G: to become F:
I want F: to become D: -in the end
24 Feb 2017   #4
RolandJS
Windows 7 Professional 64-bit
What is now using drive letter D should have no drive letters assigned to it; you're correct.
24 Feb 2017   #5
cheaterslick
Windows 7 Pro 64bit
Quote   Quote: Originally Posted by RolandJS View Post
My fear is removing the drive letter will cause it to not boot.
Would that happen?
25 Feb 2017   #6
RolandJS
Quote   Quote: Originally Posted by cheaterslick View Post
My fear is removing the drive letter will cause it to not boot. Would that happen?
I'm using Windows 7 also, and on the two computers with that partition -- keeping the partition hidden and not having any assigned drive letter to it -- the computer still posts, boots, and Windows loads every day.
25 Feb 2017   #7
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Personally I would disconnect all disks except for the one with the os on it then do startup repair
If the drive letter is not removed after startup repair then remove it manually 100mb should not have a drive letter as stated already.
C should be disk 0 anyway not disk 1.
Once all is correct then reconnect the other disks one by one and assign whatever drive letter you want to although windows often reassigns drive letter so you seem to already use labels which is good
25 Feb 2017   #8
cheaterslick
Windows 7 Pro 64bit
Well I changed the drive letters and now it won't recognize D:
Right mouse clicking the Disc 0 square leaves everything in the right-mouse menu greyed out. And it doesn't leave me with any options. What can I do next?
How do I fix a drive letter issue after doing a startup repair?-comp_mgr2.png
25 Feb 2017   #9
RolandJS
What does not recognize what used to be D? A hidden partition only shows up on disk management, not in explorer.exe. I'm doing school stuff, I'm partially distracted.
25 Feb 2017   #10
Barman58
Windows 10 Pro x64 x3, Ubuntu
D: is not showing as it has been converted to a dynamic disk ( windows own version of raid based disk sharing), The major problem now is that however this has happened it has likely deleted all or any data that was on the disk before the conversion. Assuming you have a backup of the contents of the D: drive you should be able to wipe the disk, reset it to a simple disk, reformat to NTFS, and restore your data. If you do not have backup of your data then you will need specialist software to even attempt recovery and the success rate of recovery form this type of error is extremely low
Drive letter issue in Windows 7
Hi, I have two (2) Windows 7 Ultimate installations on my PC. I have two installs because I need one particular setup for video editing resource purposes. In boot #2 I have following letters: (For Video Editing) C - Data and FSX (For General data and Flight Simulator) B - The Boot drive for...
Hardware & Devices
Drive letter changed at startup
Hello, I have a wierd problem that i don't understand: Becouse of an unfortunatly accident (whici i don't yet understand), my drive letters change, my C: became D, and so on, and logically, the windows couldn't start becouse it didn't know where windwos was. What was strange, using acronis...
Hardware & Devices
Removable devices USB port drive letter issue
I have two monitors that have ports for USB and memory card built into the side of them. When the monitor is plugged into the CPU they are assigned drive letters and become available for use. The problem I'm having is that they are sometimes interfering with my network assigned drive letters...
Hardware & Devices
Startup Repair issue?
Here is the story, a computer got a virus, and was beyond repair, So we went for a clean format. The computer was for some reason unable to boot from the windows disk, or any disk for that matter. So i hooked up the hard drive to another motherboard, and installed windows 7 from there. And hooked...
Installation & Setup
Change drive letter using Repair install?
Had an XP dual boot with Win7 RTM. Deleted XP C: drive and moved RTM D: drive over into it's space. I would like to keep and license this installation using retail Win7 Ultimate Signature Edition received with party pack. Is there a way to change the Win7 D: drive to C: by running a repair...
