Windows 7: Left mouse click brings up right-click context menu continually
08 May 2017   #11
marsmimar
This is definitely a head scratcher.
Since the problem exists no matter which mouse you use, and because it happens at random times, I'm thinking that something computer related (either hardware or software) is affecting the mouse button functions. Here are a couple of troubleshooting tutorials that might help. The first (Clean Startup) might indicate if an installed application or service is interfering in some way. The second tutorial is a long list of troubleshooting suggestions. Not every one will apply to you.
Troubleshoot Application Conflicts by Performing a Clean Startup - Windows 7 Help Forums
Troubleshooting Steps for Windows 7 - Windows 7 Help Forums
08 May 2017   #12
Ranger4
Quote   Quote: Originally Posted by cdurham View Post
I ran the sfc /scannow numerous times and I am still getting the message saying it did not fix anything. I am still having the problem with the left-click context menu appearing. This is about the fourth mouse that I have bought and they all have the left-click problem.
It would seem possible that these corrupt files might be causing the mouse problem.
How old is your hard drive?. It might be getting to the end of it's life.
Do you run regular back ups, so in the event of a complete system failure you can recover you important data & files.
08 May 2017   #13
cdurham
Windows 7 Home Premium (x64) Service Pack 1 (build 7601)
My hard drive is about 6 years old. I do occassionally backup my files onto anothe drive.
25 May 2017   #14
cdurham
I replaced the mouse and now everything works.. so far
I replaced the Logitech mouse with another mouse and everything has been working so far over the past few weeks. I believe the problem is coming from the USB extentions that I am using and this is what is causing all of the problems. Thank you all for your help!!!
25 May 2017   #15
marsmimar
Sweet. Here's hoping you've found a permanent fix. Thanks for posting back.
26 May 2017   #16
cdurham
re: mouse
Thanks!!!!
27 May 2017   #17
Layback Bear
Windows 10 Pro. 64/ version 1709
Another mouse fixed the problem. That is strange.
Your post #4
Quote:
I have tried using another mouse. The same problem still exists.
Jack
31 May 2017   #18
cdurham
re
Replacing the mouse will usually work for about 2 or 3 months and then the problem will return again.
Mouse giving right-click context menus on left-clicks
I've only had this low-end optical mouse a few months after getting it to replace the well-beaten rollerball model that came standard with this system, which I've had since 2011, but now the danged thing is getting a problem that I've seen in lots of places with relatively few solutions: the...
Hardware & Devices
Weird Mouse problem, have to hold left click to perform right click
I just bought this mouse and I thought the right click was not working but found out that I had to hold left button to perform a right click. This is my first time encountering this problem and I don't know what to do. Please help. This is the mouse: Genius
Hardware & Devices
Laptop keyboard mouse:right click and left click functions reversal
Hi, I am after some help. My laptop has decided to reverse the right click and left click functions, ie: if I left click it now does not select but instead brings up a menu (which the right click button should and used to do!) I've tried holding down both buttons (as suggested by a friend) by this...
Hardware & Devices
Left click brings up right click context menu on desktop
For the last few weeks whenever I left click on the desktop it brings the right click menu. This dosen't happen in the browser (firefox), but only in the windows desktop and start menu. However i the browser if I am on a web player like youtube, the portion that displays the video fails to display...
General Discussion
Context Menu - Right Click vs Shift Right Click
How to Expand the Windows 7 Context Menu for More Options This will show you how to expand the Windows 7 context menu to see more available options to select from for a file, folder, desktop, Windows Explorer root window, Windows Explorer window, and the Send To menu. Here's How:
Tutorials
