Left mouse click brings up right-click context menu continually
Page 1 of 3 123 LastLast
  1. Posts : 9
    Windows 7 Home Premium (x64) Service Pack 1 (build 7601)
    Hello,
    When I use my left click mouse button, the right click content menu keeps appearing. This happens often, but not everytime I click on the left mouse button. This is very annoying. I have gone into the Mouse Properties and the "Switch Primary and Secondary Buttons" box under the buttons tab is unchecked.
    I have also noticed that there are 2 HID Compiant Mice appears in the Mouse section of the Device Manager.
    I have updated drivers for the mouse.
    I have scanned for malware and viruses and I have none.
    I have even used an OS/2 connector with my USB mouse and tried to plug it into the OS/2 port but it does not work at all with the OS/2 port.
    The mouse that I am using is a Logitech B100 corded USB mouse. Any help would be appreciated.
    PC/Desktop Computer: Acer Aspire X1920 OS
    OS: Windows 7 Home Premium (x64) Service Pack 1 (build 7601)
    CPU 3.20 gigahertz Intel Pentium Dual-Core E5800
  2. Posts : 10,994
    Win 7 Pro 64-bit
    Hello cdurham and welcome to Seven Forums. No guarantees any of this will work but ...
    1. Have you restarted your computer? Sometimes that will clear up hardware or software issues.
    2. Delete one of the HID compliant mice from Device Manager (unless you actually have two different mice.)
    3. Check the box to officially switch the primary and secondary buttons. Use the mouse for a while to see if the buttons have permanently switched. (Turn the mouse upside down so buttons are at the bottom. Your hand will still left click and right click based on the switched buttons.) If mouse works without issues, uncheck the box and see if it continues to work. ( It's kinda like rebooting the mouse. :) )
    4. Run a system file checker scan from an elevated command prompt. (Option Two this tutorial.)
    SFC /SCANNOW Command - System File Checker - Windows 7 Help Forums
  3. Posts : 9,746
    Hi, cdurham, welcome to the Forum.
    Try another mouse if possible. Mice are not failure proof & do wear out after a while, so the easiest thing to do is try another mouse & if the problem disappears then it was faulty, if not then the problem is elsewhere.
  4. Posts : 9
    Re: left-click right context menu
    Hi marsmimar,
    1. I have restarted my computer many times. The mouse situation that I am having has been a problem for about 6 or 7 months and I beleive that it started when I replaced my mouse with this current mouse.
    2. I have deleted one of the HID-compliant mice numerous times. I have even uninstalled it many times. It always reappears and comes back and this does not solve the problem.
    3. I have switched the right mouse button with the left and vice versa. It seems to work that way, but I would like to have my left button function as my left button and my right button be the context menu button.
    Hi ranger,
    I have tried using another mouse. The same problem still exists.
  5. Posts : 10,994
    Win 7 Pro 64-bit
    I seem to recall that some people reported issues if the left and right mouse buttons were clicked at the same time; the buttons switched functions. (Not sure if this was brand specific or applies to any mouse.) Since some buttons are right next to each other perhaps some debris has gotten in between the buttons and occasionally causes a "sticky" effect. Even a build up of skin oil might cause the buttons to stick together. Since the same thing is happening when you switch to a different mouse this is definitely a long-shot idea.
  6. Posts : 9,746
    Did you install the Logitech B100 mouse software. If so there should be a mouse program you can open that allows you to set up the mouse to your desires.
    If there is not a desktop icon for the Logitech mouse, click on the Start button & select All Programs, then scroll down to Logitech, click on it & select Mouse or Mouse & keyboard depending on what is listed. This will open a mouse program that you can tailor to your needs & you should be able to change the how the buttons work.
  7. Posts : 9
    Ranger4
    There was no installation software that came with the Logitech mouse.
    marsimar,
    I ran the system file checker scan in cmd prompt, and so far, so good.
    Attached Thumbnails Attached Thumbnails Left mouse click brings up right-click context menu continually-image-1.jpg
  8. Posts : 10,994
    Win 7 Pro 64-bit
    System File Checker scan "found corrupt files but was unable to fix some of them." In the tutorial I provided earlier (my post # 2 above) please see the Note just below Option Two, Step 4:
    If SFC could not fix something, then run the command again to see if it may be able to the next time. Sometimes it may take running the sfc /scannow command 3 or more times to completely fix everything that it's able to.
    Try running sfc /scannow at least two more times.
  9. Posts : 9
    Okay, I will give that a try. Thanks.
  10. Posts : 9
    Nothing seems to work
    I ran the sfc /scannow numerous times and I am still getting the message saying it did not fix anything. I am still having the problem with the left-click context menu appearing. This is about the fourth mouse that I have bought and they all have the left-click problem.
