Windows 7: Case Fan Air Flow
27 Jun 2017   #1
bigmck
Case Fan Air Flow
I needed to change out my Side Fan tonight. The old one finally stopped. I checked trying to make it an Intake Fan. I installed the fan but it is blowing out. There is an Exhaust Fan in the back near the PSU. I now have two Exhaust Fans. Before I change it, I want to make sure the Side Fan should be an Intake Fan. == For next time, is there a way to tell which side of the new fan is the Intake and which is Exhaust just by looking? Thanks Guys.
27 Jun 2017   #2
Ranger4
This Youtube video should help you.
Which way does air flow go in a computer fan? - YouTube
28 Jun 2017   #3
bigmck
I appreciate the reference but that was a terrible video. :) Three minutes of him spinning the fan with his finger. == I need to know if my side fan should be an Intake since my rear is an Exhaust?
28 Jun 2017   #4
bigmck
I just "bit the bullet", took five minutes and turned the fan around so that I have one Intake Fan and one Exhaust Fan. Thanks,
 Case Fan Air Flow
Air flow question
This might seem obvious to some but i want other peoples opinions on this the define r4 black pearl case can remove both HDD Bays if you remove the top bay and swap the stock intake fan at the front on the case for lets say a Corsair AF 140 Would it be Better Than a Corsair SP 120 Fan as a Intake...
PC Custom Builds and Overclocking
No data flow
I'm connected to the Internet with a good Ethernet cord and on one side of the RJ45 I'm getting a solid green light and on the left side I'm getting a blinking amber light. I can't ping. I'm connected to a router and the other 3 computers work fine. I was thinking of removing both network adapters...
Network & Sharing
Dual boot Win7 and Flow
How can I dual boot the Flow OS (Chromium OS), along with Windows 7. It tells me I have to do it from a linux OS, or else I have to boot from it on a USB. Well I want to write it over the linux partition of my hard drive so it can boot with Win7. PS: The download comes in the form of...
Installation & Setup
Case air flow (Quick help please)
Hi, Right this moment, i'm building my first rig. I've always got a DIY system but it's set up by the people working at the store. Not sure if i connect everything properly as i've yet to start it up. That's a different thing altogether. My question: I have 2 fans installed. 1 is at the...
Air Flow
If i had a pc case with a power supply at the bottom, which way would i best be setting the fans throughout the case.????
Performance & Maintenance
