WD 5GB external USB dive Head parking problem
  1. Posts : 282
    Microsoft Windows 7 Ultimate 64-bits 7601 Multiprocessor Free Service Pack 1
    I have a WD 5TB external SATA/ USB3 drive, who seems to parks the head every 4 seconds with a dumb clicking sound that drives me nuts.
    I downloaded the software WDIDLE3 and loaded up to an USB card with Rufus bootup utility.
    Now starting this utility in DOS won't recognize the external drive?
    It starts with C:\>
    However there is no way to change that to the external drive.
    Or to get any list of available drives. (I took out the normal fixed drives/ SSD and SATA)
    It's to long ago that I did something with DOS commands so I may be wrong.
    It must be possible to change the setting of the counter in the drive to a much longer period of head parking.
    Crystaldisc is greyed out on advanced options, so that won't do either.
    Anyone have an answer?
  2. Posts : 3,786
    win 8 32 bit
    Msdos wouldn't understand NTFS or 5 gig
  3. Posts : 7,351
    Windows 7 HP 64
    Go to WD site and see if there is a firmware update to your disk.
    Software and Firmware Downloads | WD Support
      My Computers
  4. Posts : 52
    Microsoft Windows 7 Home Premium Build 7601 32bit
    5GB HDD seems awfully small.
  5. Posts : 282
    Sorry WinDozeUser, it's of course a 5 TB.
    I upgraded the driver and firmware of the HD already.
    No change.
    Samuria, maybe you're right about that, the 5 TB has also another filesystem GPT.
    I read more comments on the internet that the utility WDIDLE3 won't work on external drives.
    Not all drives are access-able to change the value of the countersettings for the headparking.
    No further reply until now from WD.
  6. Posts : 282
    Got enough of it and opened the case, took the drive out and put into my SATA adapter.
    Reboot with a bootable version of WDIDLE3. Now my drive was being recognized and I disabled the idle timer. Confirmed.
    Problem solved, the drive won't go in Idle mode anymore and there will be no more excessive head-parkings.
    (*It took approximately 900 headparkings/hour. Really silly, every 4 seconds.)
    DOS probably wouldn't recognize external drives since there are no DOS drivers.
    Sometimes you need to set the storage-mode temporarily in IDE to be able to detect a drive.
    If I now throw out the drive, it will indeed switch off.
  7. Posts : 1,784
    Linux Mint 18.2 xfce 64-bit (VMWare host) / Windows 8.1 Pro 32-bit (VMWare guest)
    If it's clicking every 4 seconds, it's probably a bad drive.
  8. Posts : 282
    Maybe, I'm going to claim a reward and get another example. I'ts already agreed.
