Windows 7: WD 5GB external USB dive Head parking problem
04 Dec 2017   #1
Bernardus
Microsoft Windows 7 Ultimate 64-bits 7601 Multiprocessor Free Service Pack 1
I have a WD 5TB external SATA/ USB3 drive, who seems to parks the head every 4 seconds with a dumb clicking sound that drives me nuts.
I downloaded the software WDIDLE3 and loaded up to an USB card with Rufus bootup utility.
Now starting this utility in DOS won't recognize the external drive?
It starts with C:\>
However there is no way to change that to the external drive.
Or to get any list of available drives. (I took out the normal fixed drives/ SSD and SATA)
It's to long ago that I did something with DOS commands so I may be wrong.
It must be possible to change the setting of the counter in the drive to a much longer period of head parking.
Crystaldisc is greyed out on advanced options, so that won't do either.
Anyone have an answer?
04 Dec 2017   #2
samuria
win 8 32 bit
Msdos wouldn't understand NTFS or 5 gig
04 Dec 2017   #3
Megahertz07
Windows 7 HP 64
Go to WD site and see if there is a firmware update to your disk.
Software and Firmware Downloads | WD Support
04 Dec 2017   #4
WinDozeUser
Microsoft Windows 7 Home Premium Build 7601 32bit
5GB HDD seems awfully small.
05 Dec 2017   #5
Bernardus
Sorry WinDozeUser, it's of course a 5 TB.
I upgraded the driver and firmware of the HD already.
No change.
Samuria, maybe you're right about that, the 5 TB has also another filesystem GPT.
I read more comments on the internet that the utility WDIDLE3 won't work on external drives.
Not all drives are access-able to change the value of the countersettings for the headparking.
No further reply until now from WD.
07 Dec 2017   #6
Bernardus
Got enough of it and opened the case, took the drive out and put into my SATA adapter.
Reboot with a bootable version of WDIDLE3. Now my drive was being recognized and I disabled the idle timer. Confirmed.
Problem solved, the drive won't go in Idle mode anymore and there will be no more excessive head-parkings.
(*It took approximately 900 headparkings/hour. Really silly, every 4 seconds.)
DOS probably wouldn't recognize external drives since there are no DOS drivers.
Sometimes you need to set the storage-mode temporarily in IDE to be able to detect a drive.
If I now throw out the drive, it will indeed switch off.
13 Dec 2017   #7
mrjimphelps
Linux Mint 18.2 xfce 64-bit (VMWare host) / Windows 8.1 Pro 32-bit (VMWare guest)
If it's clicking every 4 seconds, it's probably a bad drive.
14 Dec 2017   #8
Bernardus
Maybe, I'm going to claim a reward and get another example. I'ts already agreed.
An Interruption problem that is Doing my Head in!
Hi guys. My problem at the moment is that when I am working in a software package such a Adobe Premiere Pro or Deamweaver (or any program at all), I am getting interrupted by an unknown program that causes me to loose control of the program i.e. if I am writing in Word the interruption occurs...
General Discussion
C dive (GB)
I put in a SSD drive about a week ago and I have no data on it. So I highlighted the root directory and I have 26 GB then I right mouse click the C drive and it says I used up 34 GB and I have 10 GB which make up my win.sxs. I have a 60 GB drive so I'm getting nervous about using up too much space...
General Discussion
xbox 360 head to head gaming with PC laptop
OK I searched google and here and really can't find a solid answer to this. I have even read that windows 8 might have this feature at some point. Anyway I want to play first person shooting games like black ops from my alienware against my nephew on his xbox 360. reason for this is I have...
Gaming
New hard dive
I have been searching around and trying different methods to move windows to my new hard drive and nothing has worked. I currently have a 1 TB hard drive and I am moving to a 40GB hard drive. I have tried backing up as an image on the new hard drive but it will not boot from this. Please...
General Discussion
Nvidia + Tv Tuner Problem Doing my head in
Ok.. First post here, so ill say hi first! (long time reader first time poster :P), hope someone can help me out, it would be greatly appreciated! Ok I am running Win7, I have a winfast TV tuner card and a nvidia pcie gfx card. Up until recently, I had absolutely no problems with them...
Hardware & Devices
