Windows 7: Problem with samsung m2 external 1 tb portable hard drive
09 Jun 2018   #1
chazzy
I have made an partition and within the partition i have made another one with secret zone. After i conected the hhd on my smart tv, i have updated the tv but then my hhd become unreadable both by tv and pc! What should i do? Please help! I have many school documents and family pictures in the secret zone partition! What should I do? Many thanks for support!
09 Jun 2018   #2
Ranger4
Hi chazzy, welcome to the Forum.
Could you post screen shot of Disc Management with your external hard drive connected to the computer. Refer to this Forum link on how to post a screen shot.
Disk Management - Post a Screen Capture Image - Windows 7 Help Forums
Buffalo Ministation 1TB USB 2.0 Slimline Portable External Hard Drive
I have subject device running from Win7 64 bit. It's decided to show capacity as 49.5Gb instead of 1Tb. Any ideas welcomed. Rick
Hardware & Devices
Seagate Portable External Hard Drive Slim not detected by PC
Hello I need urgent help with resolving this as I am trying to get the harddrive showing up or at least recover files. I was using it at school first and my computer froze so I shut down the computer and restarted without safely removing the hard drive, at first the PC wouldnt reboot because I...
Hardware & Devices
I can't access my samsung external hard drive. please please help
Hi, everyone. I have a samsung s2 500 GB hard drive. It was working until yesterday, now I can't seem to access this. Here's the problem. When I plug it in, it doesn't show the SAMSUNG(P but only "local disk(P". It shows that I should format it.) Also, every time I try to right-click the local...
Hardware & Devices
Samsung s2 external hard drive not loading showing local disk F drive
I have a Samsung s2 1tb external hard drive. Today when I hooked it up to my laptop it would not load. It will shows local F drive when it usually will say samsung Drive. A pop up box will then appear stating "you need to format drive" I know if I reformat it I will lose all my data which...
Hardware & Devices
Samsung External hard drive
hi 1) I recently bought a samsung external hard (1500GB). The problem with it was that i couldn't use it on my playstation 3. i was told to format it to Fat32 (something like that), to which i used someone's link which was provided to me. After formatting it, it was still not working on my PS...
Hardware & Devices
