Power on problems began with only a motherboard pilot light and fan
The problem:
No POst but power to the motherboard apparently for devices, fans and the motherboard pilot light.
Everything else dark including the from panel Power light, HDD Light etc.
No monitor display
no beeps.
I did a few things:
I tried the drain the capacitor test by holding in the power switch for thirty secs.
Changed the battery
Changed the power supply
Checked mem stick one at a time
Cleared CMOS
System behavior was the same. I'm making this post for anyone who can spot errors I've made.
Since the front panel yoke only works on the power button (seemingly) I'm going to put on a spare
green light, red light and reset power yoke (the same kind that runs the PC I'm using for this post.) The yoke which is attached was the one running and is part of a Presario case I found-- yes found.
It's possible Compaq had something switched around from their case header. It's just unknown
as to why things woulkd just stop.
A CPU burnout just sudden like that does not seem likely since the dvd drive I have on it to test lights up and churns at power on.
This is an older board--an MSI 880GM-E41 with onboard video. I have looked at Toms Hardware and
Tech Support Forum and anything they have I've shown here.
Time passes. Progress Got three beeps with nothing else connected but a power switch for the panel.
I'll see if I can get the whole yoke on and lit up.
Not finished yet but the new yoke is on and monitor is active.
This has been an unusual problem. Panel light yoke. Who knew?
(who knew is just a US expression.)
Will mark solved shortly.
