corsair flash drive 16 gb problem
  1. Posts : 38
    Windows 7 Ultimate
    I have a 16 gb flash drive and i try to put a 7 gb iso in it and it says file is too large for destination? but my flash drive is empty.
  2. Posts : 3,960
    W7 x64
    Single file limit is 4Gb...
    If you want to carry more reformat as NTFS and go at it that way...
  3. Posts : 38
    Windows 7 Ultimate
    oo..thanks...much help...so how is it possible to get this file in?
  4. Posts : 3,960
    W7 x64
    Use something like WinRAR to split it...
  5. Posts : 38
    Windows 7 Ultimate
    actually the website had instructions on how to do it thanks you helped alot!!!
    NTFS.com Format USB Flash Drive to NTFS file system.
  6. Posts : 3,960
    W7 x64
    I'd want to keep it to FAT32 personally, and split the file... but heigh ho, whatever... as long as you're happy it's not anything gone wrong with your USB flash device...
  7. Posts : 38
    Windows 7 Ultimate
    i can reformat back at anytime right?
  8. Posts : 3,960
    W7 x64
    You sure can...
